POV-Ray : Newsgroups : povray.general : Two feature requests related to SVG Server Time
27 Feb 2026 17:13:55 EST (-0500)
  Two feature requests related to SVG (Message 1 to 10 of 15)
Subject: Two feature requests related to SVG
Date: 14 Jun 2007 22:40:02
Message: <web.4671fba4f42fd85515e9baef0@news.povray.org>
Two separate feature requests:
1) Support SVG as an import file format.
2) Copy SVG's text formatting capabilities, namely text centering and
aligning text to paths.
SVG is a standard image format and, since it is a vector format, shares many
similarities with POV-Ray. I would like to see POV-Ray adapt some of the
format's capabilities, as well as support the format via import.
-Mike
Subject: Re: Two feature requests related to SVG
Date: 15 Jun 2007 00:29:01
Message: <467214B6.8000004@joplin.com>
First time I've heard of it :0
But I don't use vector formats much. :)
Date: 15 Jun 2007 00:43:42
Message: <467218fe@news.povray.org>
> -Mike
If this were implemented, it would be nice if the user were able to call
on individual layers of the image.
SVG is an open-source format, isn't it? Being so, it would make a nice
addition to POV if it could be implemented without bloating the program.
~Sam
Date: 15 Jun 2007 05:00:46
Message: <4672553e@news.povray.org>
  What exactly would povray do with the SVG?
Date: 15 Jun 2007 05:55:02
Message: <web.467260f379affa24731f01d10@news.povray.org>
Well, it'd certainly be nice to be able to use SVGs as image_maps - no
interpolation required! I know you can almost do this already with object
patterns but it's a bit fiddly. Would it also cut down on memory usage if
you had many simple image_maps?
Lathe and prism splines can already be exported to POV by Inkscape but I
guess it would be slightly easier if the SVG file could be read directly...
Bill
Date: 15 Jun 2007 07:06:30
Message: <467272b5@news.povray.org>
  How would you determine that a given point is, for example, on a
polyline or inside a polygon?
  The thing with vector graphics is that they are easy to draw as a whole:
Just draw a line for each line in the input, fill polygons for filled
polygons, and so on. However, if you have to determine for a random point
what is its color, it becomes a bit more complicated.
Date: 15 Jun 2007 07:35:03
Message: <web.4672786979affa24731f01d10@news.povray.org>
Well, you know the line thickness. Just represent lines as additional
polygons then process only polygons (for example; there's bound to be a
quicker way).
It might not be trivial but it's hardly insurmountable. You know the
stacking order, surely it's just a matter of working down that until your
point is inside a polygon or you run out of polygons to test? It can't be
much more complicated than interpolating bitmaps.
Bill
Date: 15 Jun 2007 07:52:32
Message: <46727d80$1@news.povray.org>
>> whole:
Or just stack the polygons in the Z direction, then use an orthographic
camera and trace a ray along the Z direction, ... ermmm, hang on :-)
Date: 15 Jun 2007 15:00:01
Message: <web.4672e0ca79affa24259503b20@news.povray.org>
SVG doesn't use layers like Photoshop, AFAIK.
Date: 15 Jun 2007 15:25:04
Message: <4672e790$1@news.povray.org>
Inkscape's "Plain SVG" export includes layer functionality, though, using
the <g id="LayerName"> tag.  Surely that's something that could be parsed
on, and as plain SVG, I'd assume it's standards-compliant.
Jim
