POV-Ray : Newsgroups : povray.general : Graphical artifacts when rendering a scene Server Time
21 Nov 2025 06:46:02 EST (-0500)
  Graphical artifacts when rendering a scene (Message 1 to 3 of 3)
Subject: Graphical artifacts when rendering a scene
Date: 22 Oct 2006 02:55:01
Message: <web.453b153de4d45c8797b9615b0@news.povray.org>
I'm getting a lot of graphical artifacts when rendering the following scene.
The pigment appears speckled or mottled. I wasn't sure if this was a bug, or
if I was doing something wrong. I've tried it in 3.6.1 and the 3.7 beta with
no difference.
global_settings
 assumed_gamma 1.0
 radiosity
  brightness 0.3
background {rgb 1}
light_source
 <0, 0, 0>
 color rgb <1, 1, 1>
 translate <-30, 30, -30>
light_source
 <0, 0, 0>
 color rgb <1, 1, 1>
 rotate y * 90
camera
 location x*8
 direction 1.5*z
 look_at <0.0, 0.0,  0.0>
 rotate z*30
 rotate y*-65
sky_sphere
 pigment
  gradient y
  color_map
   [0.0 rgb <0.6,0.7,1.0>]
   [0.7 rgb <0.0,0.1,0.8>]
//------------------------------------------------------------------------------Pigments
#declare plane1P = pigment
 gradient x
 color_map
  [0 rgb <0, 0, 0>]
  [1 rgb <1, 0, 0>]
#declare plane2P = pigment
 gradient y
 color_map
  [0 rgb <0, 0, 0>]
  [1 rgb <0, 1, 0>]
#declare plane3P = pigment
 gradient z
 color_map
  [0 rgb <0, 0, 0>]
  [1 rgb <0, 0, 1>]
#declare averageP = pigment
 average
 pigment_map
  [plane1P]
  [plane2P]
  [plane3P]
 translate -x/2
 translate -y/2
 translate -z/2
 scale 2
//------------------------------------------------------------------------------CSG
objects
#declare sRadius = 1 ;
#declare sCenter = < 0 , 0 , 0 > ;
difference
 box
  sRadius * -1, sRadius
 box
  sCenter, sRadius
  scale 1.00001
 texture
  averageP
  finish
   ambient 1
 translate y * 0.001
Subject: Re: Graphical artifacts when rendering a scene
Date: 22 Oct 2006 03:20:06
Message: <453b1ba6$1@news.povray.org>
The gradient patterns change from a value of 1 to 0 right at the edge of
your object's surface. In some places, it's coming up with a value of 1, and
in others 0, causing speckling.
You can fix this by either using sRadius = 0.9999, or by adding "translate
.0001" within your texture{} block (as opposed to outside of the texture
block, where it is now).
 - Slime
 [ http://www.slimeland.com/ ]
Date: 22 Oct 2006 05:10:00
Message: <web.453b34794a7afd512670f2cf0@news.povray.org>
>  - Slime
Hey! That did the trick! Thanks!
