POV-Ray : Newsgroups : povray.general : Feature request: Native support for HSL color space Server Time
27 Dec 2025 04:39:27 EST (-0500)
  Feature request: Native support for HSL color space (Message 1 to 6 of 6)
Subject: Feature request: Native support for HSL color space
Date: 21 Oct 2006 22:45:00
Message: <web.453ada061e40103e473080560@news.povray.org>
Hi.
I would like to request that POV-Ray natively support color spaces other
than RGB (namely HSL) without having to use conversion formulas and all
that.
Thank you!
Subject: Re: Feature request: Native support for HSL color space
Date: 21 Oct 2006 23:21:29
Message: <453ae3b9$1@news.povray.org>
> that.
There's macros in colors.inc for that...
CHSL2RGB( )
I'm not sure what syntax you would sugest, you'd need a
hsl keyword similar to rgb?
pigment {color hsl <1,1,1>} // like this?
I don't care for the look of CHSL2RGB() but it can
be redefined
#macro hsl(A) CHSL2RGB(A) #end
Then you'd end up with
pigment {color hsl(<1,1,1>)}
which isn't much different.
Date: 22 Oct 2006 01:30:00
Message: <web.453b01bf2b38173297b9615b0@news.povray.org>
> > that.
> CHSL2RGB( )
Yes, that is along the lines of what I was thinking. We'd need an hslt
keyword, as well (for the transparency).
> be redefined
Does the CHSL2RGB function take transparency into account? E.g., can the
function take a color vector with more than three components? The docs
don't say.
Date: 22 Oct 2006 04:50:53
Message: <453b30ed$1@news.povray.org>
> don't say.
Yes, it can use 5d colors, or promote from 3d colors.
Date: 23 Oct 2006 07:33:03
Message: <pan.2006.10.23.11.32.16.817738@internode.on.net>
>> that.
> CHSL2RGB( )
> be redefined
Still not the same as having native support for hsl.
If I specify a colour_map with
[0 rgb<1,0,0>]
[1 rgb<0,1,0>]
then the colour at 0.5 will be rgb<0.5,0.5,0>
however
[0 hsl<0,1,1>]
[1 hsl<1,1,1>]
should give hsl<0.5,1,1> at 0.5 which still has full saturation and
luminance.
This would be very useful to have, though I can't see it happening in the
near future.
PoD.
Date: 24 Oct 2006 09:00:00
Message: <web.453e0d352b381732c150d4c10@news.povray.org>
> > that.
> CHSL2RGB( )
> be redefined
Or perhaps:
#macro hsl(A,B,C) CHSL2RGB(<A,B,C>) #end
that way a set of brackets can be dropped:
pigment {color hsl(1,1,1)}
(however, it does miss the visual cue of the vector brackets)
-tgq
