![](/i/fill.gif) |
Hello,
I have problem using fringe projection through several lenses. Hereunder my
povray code. If i project fringe through a single lens, fringe shadow
appear clearly. But if i put another lens, also with photon properties, the
shadow appear as a simple black square.
I thank you in advance for any help !
Best regards from Switzerland and have a nice day !
My code:
/*INCLUDES
/* PHOTON TUNING
global_settings {
photons {
spacing .07
gather 5,15
/* LIGHT APPEARANCE
#declare Lightbulb = union{
sphere { <0,0,0>,1 }
pigment {White}
/*BACKGROUND
background {color Cyan}
#declare ALP_H = 5;
#declare ALP_W = 5;
#declare nb_periods = 8;
#declare length_period = ALP_H / nb_periods;
#declare SinePig = pigment {
gradient y
scale ALP_H/nb_periods
sine_wave
color_map {
[0 color <0,0,0> transmit 0]
[1 color <0,0,0> transmit 1]
/* LENS PRIMITIVE
#declare R_LENS = 55.0; // sphere radius (influences magnification)
#declare K_LENS = 0.995; // overlapping coefficient (influences lens
diameter)
#declare Lens = intersection{
sphere{<0,0,0>,R_LENS translate <-K_LENS*R_LENS,0,0>}
sphere{<0,0,0>,R_LENS translate <K_LENS*R_LENS,0,0>}
pigment {White filter 1}
interior {ior 1.5}// index of refraction (Glass=1.5)
photons {
target //.25
refraction on
reflection off
/* PROJECTION SYSTEM (aligned along x axis and then rotated along z axis)
union{
/* LENS(ES)
object{Lens}
object{Lens translate<-120,0,0>}
/*SIGNAL GENERATION
intersection{
plane { x, 0
pigment {SinePig }
photons {
target //.5
refraction on
reflection off
clipped_by {
box {
<-1,-ALP_H/2,-ALP_W/2>,
<1,ALP_H/2,ALP_W/2>
translate <-1000,0,0>
/*LIGHT SOURCE
light_source {
<-2000,0,0>
2*White
cylinder
radius 10
falloff 15
point_at <0,0,0>
looks_like { Lightbulb }
/* TRANSLATION AND ROTATION
translate <-78,0,0>
rotate <0,0,-45>
/*PLANE
plane {y,0 pigment {checker color Red*0.2 color Red*0.3 scale 0.5}}
/*CAMERA
orthographic // Telecentric
location 1*<0,10,0>
look_at <0,0,0>}
![](/i/fill.gif) |
![](/i/fill.gif) |
"Louis-Severin" <lou### [at] a3 epfl ch> wrote:
> Hello,
In the message pane you get the message below;
Infinite objects: 2
Light sources: 1
Total: 6
Possible Rendering Error: Maximum trace level reached! If your scene
contains black spots read more about the max_trace_level setting in the
documentation!
Render Statistics
Image Resolution 320 x 240
Pixels: 76800 Samples: 76800 Smpls/Pxl: 1.00
Rays: 443610 Saved: 0 Max Level: 5/5
In the global settings add a line for max_trace_level
Such as;
/* PHOTON TUNING
global_settings {
max_trace_level 10
photons {
spacing .07
gather 5,15
![](/i/fill.gif) |
![](/i/fill.gif) |
Hello,
Thank you very much for your help ! It's perfect now !
Best regards,
> > Hello,
> Infinite objects: 2
> Light sources: 1
> Total: 6
> documentation!
> Render Statistics
> Such as;
> /* PHOTON TUNING
> global_settings {
> max_trace_level 10
> photons {
> spacing .07
> gather 5,15
![](/i/fill.gif) |
