![](/i/fill.gif) |
This is my first message here, so I will introduce myself briefly :
I live in the south of France, I'm 36 and in real life, I'm ground
instructor in a flight school. I've used Povray 10 years ago, when my PC
needed to compute all night long to display the famous yellow ball ;-)
I started again raytracing a few days ago, and here is my first problem (I
didn't find any solution searching the web and the news) :
I want a fire in my fog :-)
The problem is that my sphere containing the media is visible in the fog :
http://www.chezgligli.net/img/light_fog_01.jpg
I had the same problem with the water reflection and no fog, but with
max_trace_level 10 it disappeared :
http://www.chezgligli.net/img/light_fog_02.jpg
Hope someone can help ;-)
Here is the scene, the sphere and the fog are at the end :
global_settings
max_trace_level 10
#include "textures.inc"
camera
location <0, 2, -26>
look_at <0,0,10>
light_source
<0, 0, 0>, rgb <1, .2, 0>
translate <0, 5, 150>
plane
y, -1
pigment
bozo
pigment_map
[0.1 color <0, .5, .7>]
[0.3 color <.3, .8, .7>]
[0.6 color <.2, .6, .5>]
[0.9 color <0.2, .2, .9>]
turbulence .5
// L'eau / Water
box
<-150, -.9, -100>, <150, -.8, 1000>
texture
pigment
rgbf 1
normal
ripples 0.75
frequency 2
scale y*.1
turbulence .1
finish
reflection {0.1, 1 fresnel}
conserve_energy
interior
ior 1.33
// Le Soleil / the Sun
sphere // transparent sphere containing media
0, 1 pigment { rgbt 1 } hollow
interior
media
emission 1
density
spherical density_map
[0 rgb <0, 0, 0>]
[0.5 rgb <1, .3, 0>]
[1 rgb <1, 0, 0>]
scale 30
translate <0, 5, 200>
sky_sphere {
gradient y
color_map {
[0.000 0.002 color rgb <1.0, 0.2, 0.0>
color rgb <1.0, 0.2, 0.0>]
[0.002 0.200 color rgb <1.0, 0.2, 0.0>
color rgb <0.2, 0.2, 0.3>]
scale 2
translate -1
rotate -95*x
// Flammes / Flames
sphere
<0,0,0>, 1
hollow
no_shadow
pigment {rgbf 1}
scale <.6, 1, .3>
interior
media
intervals 5
samples 5
emission 6
absorption 1
density
spherical
scale <5, 25, 4>
warp
turbulence 10 lambda 2 octaves 4
density_map
[0 rgb 0]
[.5 rgb 0]
[.7 color Orange]
[.8 color Orange]
[.9 color Red]
[1 color Red ]
translate <2, 2, -20>
// Brouillard / Fog
#declare Brouillard=1;
#if(Brouillard)
fog
distance 8
color rgbf<.8, .9, .8, 1>
fog_type 2
fog_offset 2
fog_alt 1
turbulence <1, 1, 1>
turb_depth .8
octaves .2
lambda .5
omega 1
![](/i/fill.gif) |
![](/i/fill.gif) |
> #if(Brouillard)
> fog
> distance 8
> fog_type 2
> fog_offset 2
> fog_alt 1
> turb_depth .8
> octaves .2
> lambda .5
> omega 1
> #end
Remove the filter component from your fog color and it should work, i.e.
"color rgb<.8, .9, .8>".
I forget the long explanation behind this, but I had the same issue for
my "mystery lights" IRTC entry, and there was a good description posted
here when I asked. The final answer though was that fog with a filter
component results in an incorrect calculation along the length of the
ray so you end up seeing the media container.
RG
![](/i/fill.gif) |
