POV-Ray : Newsgroups : povray.general : Unwanted cartoon-like flames! Server Time
28 Feb 2026 09:39:13 EST (-0500)
  Unwanted cartoon-like flames! (Message 1 to 4 of 4)
Subject: Unwanted cartoon-like flames!
Date: 8 May 2006 11:15:00
Message: <web.445f6017fcc530d2a8eb78fb0@news.povray.org>
Hi!
I've got an array of ships with engines at full throttle... when I render
the scene I've got this strange effect:
http://img278.imageshack.us/img278/3478/ships2nu.jpg
the ship at the top is ok! but the flames of the others ships looks
innaturals (no gradient... only white and red)!
Why?
Render parameters:
-w800 -h450 +a0.3
global_settings {
    assumed_gamma 1 // tweak if the image is too pale
    max_trace_level 20
       radiosity {
            count 35 error_bound 1.8
            recursion_limit 1
            low_error_factor .5
            gray_threshold 0
            minimum_reuse 0.015
            brightness 1
            adc_bailout 0.01/2
            normal on
            media off
media {
  scattering {
       1, // isotropic
       rgb 0.02
This is the flame:
#declare carFlame2=
union
    cone {
       <0,0,0>,0.5,<0,0,1>,0.3
       hollow
       pigment {rgbt <0,0,0,1>}
       interior {
          media
         { emission 4
           density
           { spherical density_map
             { [0 rgb 0]
               [0.4 rgb <1,0,0>]
               [0.8 rgb <1,0,0>]
               [1 rgb <1,0,0>]
    cone {
       <0,0,0.4>,0.3,<0,0,1>,0.25
       hollow
       interior {
          media
         { emission 10
           density
             { [0 rgb 0]
               [0.4 rgb <1,1,0.502>]
               [0.8 rgb <1,1,0.502>]
               [1 rgb <1,1,0.502>]
    cylinder {
       <0,0,0.95><0,0,1>,0.2
       pigment {rgbf <1,1,1,0.1>}
       finish{ambient 1}
    cylinder {
       <0,0,0.96><0,0,1>,0.21
        hollow
       pigment {rgb <0,0,0,>}
Thanks!
Dox
Subject: Re: Unwanted cartoon-like flames!
Date: 8 May 2006 19:52:06
Message: <445fd9a6$1@news.povray.org>
danyolgiax nous apporta ses lumieres en ce 08/05/2006 11:13:
> Hi!
> Why?
> Render parameters:
> -w800 -h450 +a0.3
> global_settings {
>     max_trace_level 20
>        radiosity {
>             recursion_limit 1
>             low_error_factor .5
>             gray_threshold 0
>             minimum_reuse 0.015
>             brightness 1
>             adc_bailout 0.01/2
>             normal on
>             media off
> media {
>   scattering {
>        1, // isotropic
>        rgb 0.02
> This is the flame:
> #declare carFlame2=
> union
>     cone {
>        hollow
>        interior {
>           media
>          { emission 4
>            density
>              { [0 rgb 0]
>                [0.4 rgb <1,0,0>]
>                [0.8 rgb <1,0,0>]
>                [1 rgb <1,0,0>]
>     cone {
>        hollow
>        interior {
>           media
>          { emission 10
>            density
>              { [0 rgb 0]
>                [1 rgb <1,1,0.502>]
>     cylinder {
>        finish{ambient 1}
>     cylinder {
>         hollow
> Thanks!
> Dox
Your emission values are to large causing an oversaturation of the colours. emission 4
and 10
effectively multiply your colour_map by 4 and 10 respectively. The red part been only
red, you don't
realy see this, but, for the yellow part, you get an effective value of <10, 10, 5.02>
witch gets
clipped to <1,1,1>.
When the "flame" get's scaled down, the reduced thickness reduce this effect.
AAAAAA: American Association Against Acronym Abuse and Ambiguity.
Date: 9 May 2006 10:00:01
Message: <web.4460a01c4550e8cea8eb78fb0@news.povray.org>
I tryied replacing 4 and 10 with 0.4 and 1 but flames density is too
transparent... quite invisible! How can I do?
> > Hi!
> > Why?
> > Render parameters:
> > -w800 -h450 +a0.3
> > global_settings {
> >     max_trace_level 20
> >        radiosity {
> >             recursion_limit 1
> >             low_error_factor .5
> >             gray_threshold 0
> >             minimum_reuse 0.015
> >             brightness 1
> >             adc_bailout 0.01/2
> >             normal on
> >             media off
> > media {
> >   scattering {
> >        1, // isotropic
> >        rgb 0.02
> > This is the flame:
> > #declare carFlame2=
> > union
> >     cone {
> >        hollow
> >        interior {
> >           media
> >          { emission 4
> >            density
> >              { [0 rgb 0]
> >                [0.4 rgb <1,0,0>]
> >                [0.8 rgb <1,0,0>]
> >                [1 rgb <1,0,0>]
> >     cone {
> >        hollow
> >        interior {
> >           media
> >          { emission 10
> >            density
> >              { [0 rgb 0]
> >                [1 rgb <1,1,0.502>]
> >     cylinder {
> >        finish{ambient 1}
> >     cylinder {
> >         hollow
> > Thanks!
> > Dox
4 and 10
only red, you don't
5.02> witch gets
> clipped to <1,1,1>.
> Alain
Date: 9 May 2006 13:06:29
Message: <4460cc15$1@news.povray.org>
Well, IIRC, there are some numbers left between 0.4 and 4 (or between 1
and 10). Did you try some of them? ;)
If the effect looks too transparent, increase the numbers, render again.
If the effect is too strong, reduce the numbers again. You should have a
value that fits your needs after about 4 steps (Of course you can fine
tune the values as long as you want :)
HTH,
Florian
