POV-Ray : Newsgroups : povray.general : large renderings Server Time
21 Nov 2025 13:17:15 EST (-0500)
  large renderings (Message 1 to 6 of 6)
Subject: large renderings
Date: 23 Apr 2006 17:25:00
Message: <web.444bef9ba5dd5102b4cb904a0@news.povray.org>
Hello all,
I have some questions regarding large renderings.
(I'm using the command line version of povray for
linux/unix.)
1) Lets say I have a target size of some 10thousand
pixels height and width, like 40000x30000 pixels.
And I only want to render a part of it at a time
so I can handle the resulting images easier. I can
specify the wanted start/end-row and start/end-column
but povray still creates a image of the *whole* size
with only the rendered part in it. How can I avoid this
and make povray create an image only of the size of the
wanted part? I didn't find an appropriate command line
switch.
Of course I still can cut out the resulting part with
an image manipulation tool, but...
2) When specifying a region in the image, is the first
line called 1 or 0? The man page again doesnt say some-
thing about this. So e.g. if I want to render the first
400 columns, should I specify "+SC0 +EC399" or "+SC1 +EC400"?
3) Is there any limitation to the size of the resulting image?
Part of the image or the whole image?
Thanks and regards,
Leander
Subject: Re: large renderings
Date: 23 Apr 2006 17:40:00
Message: <web.444bf33b4386f8bed22f45810@news.povray.org>
"Leander" <nomail@nomail> wrote:
> 2) The man page again doesnt say some-
> thing about this.
Of course not. That is why there is a whole user manual included with
POV-Ray! You may want to read it.
In the online version the answer to all your questions is at:
<http://www.povray.org/documentation/view/3.6.1/217/>
Date: 24 Apr 2006 04:15:03
Message: <e2i17o$k8g$1@chho.imagico.de>
Leander wrote:
> [...]How can I avoid this
> switch.
There isn't.
The partial images are usable though - i once wrote a small shell script
that extracts a selected part from such an image:
http://www.imagico.de/pov/img_crop.sh
You should turn off display of course but apart from that - no*.  Except
of course limitations of the file system concerning file size and size
limits of the image file formats.
*) up to the usual numerical limits of 32bit integers (2.1 billion)
http://www.imagico.de/ (Last updated 14 Mar. 2006)
Date: 24 Apr 2006 15:48:18
Message: <444d2b82$1@news.povray.org>
40000x30000 is 1.2 billion pixels.  As a 24-bit uncompressed bitmap,
that would take 3.6 gig of storage.
Certainly the largest image I'd ever come across.
-DJ
Date: 25 Apr 2006 04:21:42
Message: <pdbNOSPAM-CDF605.18213925042006@news.povray.org>
> switch.
The way PovRay handles this is a matter of contention, I for
one an often frustrated by the approach taken. I regularly
(at least in the past) render these sizes and often in strips.
The way it used to work was that while PovRay created a file
with the final dimensions, the actual image data was only the
piece you asked for. Very annoying since this is an illegal
image. One of the ways I used to get around this was to save
as TGA and write mmy own code that joined the bits together,
ignoring the file size header information.
Let me know if this has changed, ie: the image is now black
or equivalent except for the piece requested.
0 to 399 I believe.
I believe you are limited to 32bit ints for each dimension, haven't
tried to test this though.
Paul Bourke
pdb(NOSPAM)swin.edu.au
Date: 25 Apr 2006 13:46:26
Message: <444e6072@news.povray.org>
Just visit
http://earthobservatory.nasa.gov/Newsroom/BlueMarble/BlueMarble_monthlies.html
and download 86400x43200 RGB images with 3.7 billion pixels :-)
mat### [at] matweide
http://www.matwei.de
