POV-Ray : Newsgroups : povray.general : float/double precision Server Time
21 Nov 2025 16:25:39 EST (-0500)
  float/double precision (Message 1 to 5 of 5)
Subject: float/double precision
Date: 25 Jan 2006 00:35:01
Message: <web.43d70dd51ae590815820684d0@news.povray.org>
Does POVRay use double precision numbers anywhere in its fields or calcs?
Subject: Re: float/double precision
Date: 25 Jan 2006 06:26:29
Message: <43d76065@news.povray.org>
  I wonder why you think that 'double' wouldn't be the default type used
by POV-Ray for its calculations.
  AFAIK the only places POV-Ray uses 'float' is in color handling (ie.
the colors of the final image, which end up as pixels in the final image
file) and mesh coordinates.
Date: 26 Jan 2006 20:35:00
Message: <web.43d977bbbbb99ad95820684d0@news.povray.org>
In the help provided with the program:
a search on "float" reveals endless references to float,
such as: all floating point functions, vector litterals, user defined
functions,
teh machine epsilon documented is rather large, pretty muich all parameters,
such as global settings, the transformation matrix is 12 float vectors, ...
and so on.
searching on double finds much less.  though there is a para. on 3DNow which
states that POVRay needs double precision.
cheers,
chris
Date: 27 Jan 2006 04:15:46
Message: <20060127091609.42eafdc6@mekanori.mon.istic.org>
The user documentation doesn't trouble itself to distinguish between
single and double precision, subsuming them all as floating-point
numbers. If you search the source for references to SNGL and DBL (which
are typedef'd appropriately), you will find fewer areas where SNGL is
mentioned.
"Of all  things,  good sense is  the most fairly  distributed:  everyone
thinks  he is  so well  supplied  with it  that even  those who  are the
hardest to satisfy in  every other respect never  desire more of it than
they already have."   --  Descartes, 1637      http://surreal.istic.org/
Date: 27 Jan 2006 06:01:03
Message: <43d9fd6f@news.povray.org>
  In the documentation "float" is just short for "floating point number".
It doesn't refer to its size.
