POV-Ray : Newsgroups : povray.general : Static Noise Server Time
30 Sep 2024 21:29:53 EDT (-0400)
  Static Noise (Message 1 to 9 of 9)
Subject: Static Noise
Date: 14 Nov 2005 15:35:01
Message: <web.4378f47765bd349b28323aad0@news.povray.org>
I'm trying to create a static noise effect, like when your TV seems to fail.
I've allready tried MegaPOV's noise-pigment (monochromic) but the result
still isn't what I'm looking for, can anybody give me some advise?
Thanks
Subject: Re: Static Noise
Date: 14 Nov 2005 17:06:13
Message: <43790a55@news.povray.org>
iceqb nous apporta ses lumieres en ce 2005-11-14 15:32:
> Thanks
You may try a cells pattern scaled relatively small and using a relatively sharp
colour_map.
Something like:
pigment{cells colour_map{[0.3 rgb 0][0.7 rgb 1]} scale 0.01}
Adjust the colour_map and scale to your needs.
'Honesty is the best policy, but insanity is a better defense'
Date: 14 Nov 2005 17:25:00
Message: <web.43790d9160c7a1428323aad0@news.povray.org>
colour_map.
> Something like:
> Alain
thanks, i'll try that, can i also use cells in media, or is it strictly a
pigment and normal-pattern?
Date: 14 Nov 2005 17:41:00
Message: <ncgn43-n2j.ln1@raf256.com>
iceqb <web.43790d9160c7a1428323aad0@news.povray.org> Monday 14 of November
2005 23:20
Hmm, I _think_ the goal is to remember that TV texture is discreet with
limited resolution of about 700x500 pixels, while normal POVray pigments
have almost "infinite accuaraycy".
Perhaps you shold created image texture, hmm I forgot the syntax (someone
can remind me?) but it was like
pigment 700,500 {
  bozo ...
  scale ...
Date: 14 Nov 2005 17:46:02
Message: <437913aa$1@news.povray.org>
> Thanks
I simply use a bumps pattern, scaled down so taht it looks like snow on
the tv screen.  A color map color_map { [.4 rgb 0][.6 rgb 1] } will work
fine.
Make sure you translate the pattern with the clock, in a direction
perpendicular to the TV screen, so that the snow appears to randomly
change over time.
John
Date: 15 Nov 2005 08:50:00
Message: <web.4379e6ca60c7a1428323aad0@news.povray.org>
> 2005 23:20
> pigment 700,500 {
>   bozo ...
>   scale ...
Thanks for the tip, but I'm actually trying to achieve a realistic
light-emission from the tv, it's supposed to be the only light_source in
the scene. I thought about a light_source behind a transparenc map, but
that didn't work out. So I'm using or a high ambient value in combination
with radiosity, or emmisive media.
The suggestion about an image_map is good, because the texture didn't seem
quite wright.
thanks
Date: 15 Nov 2005 09:07:41
Message: <uk6p43-fn9.ln1@raf256.com>
iceqb <web.4379e6ca60c7a1428323aad0@news.povray.org> Tuesday 15 of November
2005 14:46
If You are using MegaPov (PovRAY + more-futures-patch) then keywords like
no_image no_reflection no_radiosity will be helpfull
> quite wright.
Date: 15 Nov 2005 10:15:00
Message: <web.4379fb5460c7a1428323aad0@news.povray.org>
> 2005 14:46
I mostly use MegaPOV instead of POV-Ray, thanks for the tip.
Date: 15 Nov 2005 21:54:48
Message: <437a9f78@news.povray.org>
iceqb nous apporta ses lumieres en ce 2005-11-14 17:20:
colour_map.
>>Something like:
>>Alain
You can use it about anywhere: normal, pigment, texture, material, density.
Get a new car for your spouse. It'll be a great trade!
