POV-Ray : Newsgroups : povray.general : Random solid colors for the hexagon block pigment pattern Server Time
30 Sep 2024 21:29:53 EDT (-0400)
  Random solid colors for the hexagon block pigment pattern (Message 1 to 6 of 6)
Subject: Random solid colors for the hexagon block pigment pattern
Date: 7 Nov 2005 17:25:00
Message: <web.436fd3c2e2eb0cf59e8613510@news.povray.org>
Hey, I've been wrangling with this for a few hours:
I'm trying to use the hexagon pigment pattern (as one of several function
for creating a height field) and instead of a repeating pattern of 3 colors
I'd like to have each hexagon given a random solid color. Is this possible?
Thanks so much,
Stefan Sittler
Subject: Re: Random solid colors for the hexagon block pigment pattern
Date: 7 Nov 2005 18:59:04
Message: <436fea48$1@news.povray.org>
Yes.  Here's an entire POV file to demonstrate:
// start of POV-Ray file
#declare pigA=pigment { cells
   warp { repeat z offset <-.5,10,0>}
   translate z/2
   scale <3,1,sqrt(6.75)>
#declare pigB=pigment { cells
   translate <1.5,7,0>
#declare pigC=pigment { cells
   translate <0,-7,0>
plane { y,0
   pigment { hexagon pigment {pigA} ,pigment { pigB} , pigment {pigC} }
light_source { 1e4 1 }
camera { location 10 look_at 0 }
// end of POV-Ray file
John
Date: 8 Nov 2005 16:30:00
Message: <web.4371186bab22bf96facdf0790@news.povray.org>
Thank you very much!
Date: 17 Nov 2005 15:05:01
Message: <web.437ce1dfab22bf968c7259570@news.povray.org>
> Regards,
> John
OK, I see THAT it works (and by adding color_maps you can get all kinds of
cool stuff); I'm still trying to puzzle out WHY it works.
Anyway, yet another useful trick from the files of Mr. VanSickle.
Dave Matthews
Date: 17 Nov 2005 16:15:40
Message: <437cf2fc$1@news.povray.org>
>>Regards,
>>John
Well you get that the cells pattern gives you random stepped colors
based on the map you feed it, right?  So it is an easy way to have a)
random values, b) stepped values, meaning a cell is all one color c) a
regular grid pattern.  (As someone else pointed out, you can get b), the
stepped effect, from other patterns too by manipulating the color_map)
John is nesting the cells pattern, as it were, within the hexagon
pattern.  It's like the hexagon pattern is a sort of mask with the cells
pattern forming the color behind. I posted a similar thing here to get
random brick textures. His method for scaling and warping the cells
pattern to the hexagon pattern is typically ingenious however, and
opaque to me, naturally.
Date: 17 Nov 2005 17:10:01
Message: <web.437cfe6bab22bf968c7259570@news.povray.org>
Actually, (embarassingly) no, that's what I didn't get.  I should have
looked over the "cells" documentation again.  And the rest of your
explanation, although I had figured it out, is much clearer than the way I
was previously thinking about it.
Thanks!
Dave Matthews
