POV-Ray : Newsgroups : povray.general : Alpha Channel question Server Time
19 Mar 2026 16:56:43 EDT (-0400)
  Alpha Channel question (Message 1 to 3 of 3)
Subject: Alpha Channel question
Date: 22 Oct 2005 21:55:00
Message: <web.435aece5bf6105027715d460@news.povray.org>
A quick question. Is there a way to set the color of the masked data to
something other than black in the output image when Alpha Channel is
enabled?
I use a lot of black in my images, and it gets hard to separate the actual
rendered objects from the rest of the image.
Thanks.
Shark
Subject: Re: Alpha Channel question
Date: 22 Oct 2005 22:00:22
Message: <435aeeb6$1@news.povray.org>
> enabled?
When alpha output is enabled, the background color shouldn't show at all
(except in reflections and refraction). When there's a partially transparent
object, even if your background color is set to bright orange, you should
only see the color of the object (along with its transparency) - no orange.
Make sure you have the latest version of POV-Ray for this behavior (I'm not
sure 3.5 did it this way).
If you're referring to the background color appearing in reflections, just
set it with background{rgb whatever}.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 14 Nov 2005 15:30:00
Message: <web.4378f2b71e3d0f5a294338110@news.povray.org>
Ah, thanks! But, I found that it was an issue with my image editor.
> > enabled?
>  - Slime
