![](/i/fill.gif) |
A quick question. Is there a way to set the color of the masked data to
something other than black in the output image when Alpha Channel is
enabled?
I use a lot of black in my images, and it gets hard to separate the actual
rendered objects from the rest of the image.
Thanks.
Shark
![](/i/fill.gif) |
![](/i/fill.gif) |
> enabled?
When alpha output is enabled, the background color shouldn't show at all
(except in reflections and refraction). When there's a partially transparent
object, even if your background color is set to bright orange, you should
only see the color of the object (along with its transparency) - no orange.
Make sure you have the latest version of POV-Ray for this behavior (I'm not
sure 3.5 did it this way).
If you're referring to the background color appearing in reflections, just
set it with background{rgb whatever}.
- Slime
[ http://www.slimeland.com/ ]
![](/i/fill.gif) |
![](/i/fill.gif) |
Ah, thanks! But, I found that it was an issue with my image editor.
> > enabled?
> - Slime
![](/i/fill.gif) |
