POV-Ray : Newsgroups : povray.general : Help! Eyelashes: Trace? Server Time
28 Feb 2026 17:19:01 EST (-0500)
  Help! Eyelashes: Trace? (Message 1 to 4 of 4)
Subject: Help! Eyelashes: Trace?
Date: 12 Oct 2005 16:00:00
Message: <web.434d698a93356c48602b380@news.povray.org>
I am designing a character, mainly with blobs. I want to add eyelashes but I
have trouble determining where to put the lashes. I have a blob-sphere for
the head with a blob-sphere for the eyelids. The eye opening is a squashed
negative-strength blob-cylinder which I scale according to how far open the
eyes are. The eyelashes need to be at the edge where the eyelid and
negative blob-cylinder meets. Does anyone know how I can determine this
please?
Regards
Nekar Xenos
Subject: Re: Help! Eyelashes: Trace?
Date: 14 Oct 2005 12:21:12
Message: <434fdaf8$1@news.povray.org>
"Nekar Xenos" <go_### [at] yahoocom> wrote in message
news:web.434d698a93356c48602b380@news.povray.org...
>I
> the
> please?
> Regards
> Nekar Xenos
Hi Nekar,
I don't know of a simple way, though someone with a better feel for blobs
may be able to tell you how to calculate where the boundary comes.
You're right that it can be done with Trace. There's probably loads of ways
to approach it, but I would suggest identifying a series of start points
that would form an arc a short distance outside an eyelid as you look down
from above.
If you select a height that aligns with your negative strength cylinder,
then it should be level with the opening. You could then send out a series
of traces from each start point, scanning vertically to find the two
intersection points closest to that start point (one above the horizontal,
one  below).
I would then store the upper eye line positions in an array and the normals
in a second array and use a loop to position eye lashes uniformly along the
line. I've got SDL to do this last little bit (the easy bit) if you're
interested.
Chris B.
Date: 15 Oct 2005 11:30:00
Message: <web.43511fd96c22d3088602b380@news.povray.org>
> Hi Nekar,
> from above.
> one  below).
> interested.
> Regards,
> Chris B.
Thanks, this is roughly along the lines that I tried, but it looks like what
I really need here is a mathematical formula to determine where the
positive and negative blobs meet.
Nekar Xenos
Date: 30 Oct 2005 21:37:53
Message: <43658381@news.povray.org>
First of all you always have the option of being a non-purist and just make
a
union{
        your_blob_object
        difference{sphere{}
                   slightly smaller sphere{}
                   cylinder{}
        and then rotate this differenced object as you would an eyelid.
Secondly, you could make the object that cuts the eye-hole rotate itself,
then you could just give eyelashes the same transform as the eyelid.
> I have trouble determining where to put the lashes.
