POV-Ray : Newsgroups : povray.general : Scene file compatibility issue Server Time
14 Sep 2025 18:52:59 EDT (-0400)
  Scene file compatibility issue (Message 1 to 9 of 9)
Subject: Scene file compatibility issue
Date: 27 Sep 2005 15:20:01
Message: <web.43399b04344cec4b40d52b80@news.povray.org>
I recently rendered some old scene files that created years ago using PovRAY
v1.0 and noticed some odd differences in the way light and objects
interact.
the difference.
Does anyone know what change in newer versions of PovRAY cause the objects
to be completely opaque and what I would need to change to make them only
The version 3.6 command-line used to render the scene was:
povray +MV1.0 +w320 +h200 -d -x -v -p +ft +A0.3 +ilit01.pov +olit01.tga
The scene file is:
// Scene File: lit01.pov
#include "textures.inc"
camera
  location  <0 1 -3>
  direction <0 0 1.5>
  up        <0 1 0>
  right     <1.33 0 0>
  look_at   <0 1 2>
  rotate    <1.25 0 0>
  rotate    <0 15.5 0>
// ++++++ a backdrop wall
object
  plane { <0 0 1> 7}
  texture { color Gray }
// ++++++ a neutral but patterened floor for reference
object
  plane { <0 1 0> 0 }
  texture
    checker
      color White
      color Gray
// ++++++ a light in a box shining through a slot
composite
  object
    difference
      box{ <-.125 -.125 -.125> <.125 .125 .125> }
      box{ <-.015 -.120 -.120> <.015 .120 .130> }
    texture
      color blue .45 red .35 green 1
  object {light_source { <0 0 -.100> color green 1} }
  translate <0 .125 .125>
composite
  object
    difference
       difference
         box{ <-.120 -.120 -.120> <.120 .120 .120> }
       box{ <-.015 -.120  .115> <.015 .120 .130> }
    texture
      color blue .35 red 1 green .45
  object {light_source { <0 0 -.100> color red 1} }
  translate <.5 .125 .125>
composite
  object
    difference
    texture
      color blue 1 red .35 green .45
  object {light_source { <0 0 -.100> color blue 1} }
  translate <-0.5 .125 .125>
// ++++++ some ambient over all light
object {light_source {<2 4 -3> color Gray70}}
--- 1Daedalus
Subject: Re: Scene file compatibility issue
Date: 27 Sep 2005 17:03:34
Message: <4339b3a6$1@news.povray.org>
> "mostly" opaque as they were in version 1.0?
"composite" must be ancient, I'm not sure I've even heard of it before.
Anyway, the objects *are* opaque, they have no transparency in their colors.
Maybe you want double_illuminate?
 - Slime
 [ http://www.slimeland.com/ ]
Date: 28 Sep 2005 00:47:05
Message: <433a2049$1@news.povray.org>
Before double_illuminate was introduced, surfaces of some objects would
become double-illuminated under various (mostly undocumented) circumstances.
In MegaPOV and then later in the official POV-Ray, we made the behavior
consistent and unambiguous, but then added the double_illuminate keyword to
allow the feature (a.k.a. bug) to be turned back on when it was needed (thus
making it a true feature and not a bug).
The bicubic_patch was notorious for always being double-illuminated before
this change was introduced.
-Nathan
"Slime" <fak### [at] emailaddress> wrote...
objects
only
colors.
>  - Slime
Date: 28 Sep 2005 05:05:29
Message: <433a5cd9@news.povray.org>
  I think that mesh was even more notorious for this.
  There was a quite good reason, though: It elliminated this problem:
http://tag.povray.org/povQandT/SmoothTriangleArtifact/index.html
  When the implicit double-illumination was removed (in pov3.5, iirc),
this problem immediately surfaced. :P
Date: 28 Sep 2005 10:00:01
Message: <web.433aa15520f425dc40d52b80@news.povray.org>
Thanks for the link, I found the technical discussion illuminating. ;-)
-- 1Daedalus
Date: 19 Oct 2005 13:00:01
Message: <web.43567b6a20f425dc40d52b80@news.povray.org>
> >                                                           - Warp
> -- 1Daedalus
fyi, for anyone who reads this thread, suggestions to try
"double-illumination" or transparency are off track.  The
double-illumination keyword only applies to surfaces, not solids.
Transparency doesn't work either, it tends to make the objects see-through
rather than transluscent.
-- 1Daedalus
Date: 20 Oct 2005 04:19:48
Message: <43575324@news.povray.org>
1Daedalus <nomail@nomail> wrote:
> The
  There are no solids in povray. Everything is a surface.
Date: 20 Oct 2005 09:19:11
Message: <4357994f$1@news.povray.org>
What of media?  (And according to dictionary.com, there most certainly
are solids in POVRay; "of or relating to three-dimensional geometric
figures or bodies", "a geometric figure having three dimensions")
Tim Cook
Version: 3.12
Date: 20 Oct 2005 10:23:45
Message: <4357a870@news.povray.org>
> What of media?
  Media does not act like an object. It cannot reflect nor refract rays,
nor it has a surface other than defined by a true object. You cannot
have a media "object" all by itself; either it is contained by a true
object or it occupies the entire universe.
  POV-Ray only handles surfaces, not solid objects. It's basically
impossible to handle solid objects with raytracing.
  What's the difference, you might ask? The difference is that when you
apply a texture to an object, the texture is applied to the surface only
(because the object is a surface, nothing more). This is evident when
parts of the texture are transparent.
  It's also evident when you clip an object.
