POV-Ray : Newsgroups : povray.general : Does anyone know how to achieve a fiber-optical effect? Server Time
16 Apr 2026 06:09:14 EDT (-0400)
  Does anyone know how to achieve a fiber-optical effect? (Message 1 to 5 of 5)
Subject: Does anyone know how to achieve a fiber-optical effect?
Date: 30 Jul 2005 22:45:00
Message: <web.42ec3a5f65a378c192a4d1390@news.povray.org>
So, here's the situation: I'm working in POV-Ray, and I get an idea like
this: "Hey, maybe I could light up this whole column of objects and have
them all glow due to a light-emitting object at the bottom!"(I'm using
radiosity). Is there any way to use an interior to get an effect similar to
what happens when you feed light into a fiber optic line, where the entire
wire seems to glow with a quiet red light? I don't want to fake it by using
ambience, I want this to be an authentic glow. Has anyone achieved this, or
knows how?
Subject: Re: Does anyone know how to achieve a fiber-optical effect?
Date: 31 Jul 2005 07:09:50
Message: <42ecb17e$1@news.povray.org>
"FractalMBrown" <fractalmbrown_AT_QX_DOT_NET> wrote in message
news:web.42ec3a5f65a378c192a4d1390@news.povray.org...
> to
> using
> or
> knows how?
Hmmmm, thinking media-filled objects could be the answer. Radiosity will
affect that when you use 'media on' in the radiosity statement. That plus
photons and reflective/refractive objects might work all together if you use
actual light source(s) in conjunction with radiosity. Not real sure it would
do exactly as you want though.
I can't think of an example of such a thing. I did a fiber-optic cable long
ago but it was only to get light out the other end (was not entirely
successful).
Bob Hughes
Date: 31 Jul 2005 12:10:01
Message: <web.42ecf7329b6fe62192a4d1390@news.povray.org>
> successful).
> Bob Hughes
Thanks, I'll have to learn how to use media (I'm still learning all the
features), but I'll keep your advice in mind.
Subject: I was mistaken about media+radiosity
Date: 2 Aug 2005 06:45:19
Message: <42ef4ebf@news.povray.org>
When I said radiosity affects media, well, that was a misnomer. I was
checking about this just tonight as I finally thought on this some more and
tried a test scene to be sure it could work okay.
Seems that media affects radiosity instead of the other way around. For
example, a very diffuse white block below a clear tube filled with red media
(emission <1,0,0>) will glow red, but the media won't be brightened by the
block FAIK. Without light sources there's no way to scatter the light into
the media so the block will remain dark unless ambient and even so the media
remains unaffected..
Sorry that I led you astray. So for doing that I'll try and make up for it
by giving an example of something like what you asked about, even if it
might not be exactly the same thing I thought you might have been asking.
The following script is a quick hack, so please keep that in mind. Photons
optional.
/* tube glowing red from light below it */
global_settings {
 assumed_gamma 1.0
 ambient_light 0//1
 radiosity {
  count 123
  brightness 1
  media on
 photons {
  count 5000 // increase...?
  media 100, 2
sphere {
 0,100
 pigment {color rgb 0.5}
 inverse
 location <1,2,-6>
 angle 50
 look_at -y
box {
 -1,1
  color rgb 1
 finish {
  ambient 1
  diffuse 1
 scale <2,0.5,1>
 translate -2.01*y
 photons {
  target 0
  collect off
light_source { // between cylinder and box
 -1.125*y,1
 photons {
  refraction on
  reflection off
cylinder {
 -y,+y,0.5
  color rgbt 1
 interior {
  ior 1.48
  fade_distance 0.25
  media {
   samples 15
   emission <1,0,0>//10 // divide by 10 if using photons
   absorption <0.1,0.1,0.1>
   scattering {
    2,<0.5,0,0>//10 // divide by 10 if using photons
   density {
    function {abs(y)}
    density_map {
     [0 rgb 0] // use rgb 1 for even distribution
     [1 rgb 1]
    scale 2
    translate y
 hollow
 photons {
  target 0 // 1 for photons effect
  refraction on
  reflection off
  collect off
Subject: Re: I was mistaken about media+radiosity
Date: 6 Aug 2005 09:10:01
Message: <web.42f4b59ddcc5f99092a4d1390@news.povray.org>
> optional.
> Bob
   (Clipped)
Thanks, I'll try it out as soon as I can! (I can't try it right now
considering how I'm doing a 12000x8000 render and it's going to take about
30 hours at this rate)
