POV-Ray : Newsgroups : povray.general : big problem cmedit32.dll Server Time
19 Mar 2026 20:48:07 EDT (-0400)
  big problem cmedit32.dll (Message 1 to 2 of 2)
Subject: big problem cmedit32.dll
Date: 22 Jul 2005 16:55:00
Message: <web.42e15c7962bd4bb7b1049cb0@news.povray.org>
Hi all,
I will try to describe my problem as clear as possible:
I installed the latest version (3.6) of POV-Ray a couple of days ago. During
these days I did some experiments - especially to export some models from
available (pay-and freeware) modelers around the scene into POV.
As far as good. But suddenly - from one moment to the other, the launching
of POV fails. Doing a new start of the program, the famous MS-message comes
up: An error has occured (cmedit.dll) and the program must shut down.....
So I deinstalled the program, had a look at the regestry and some files,
stored under `documents and settings` and so far. All of them I could
located, was removed, now.
After a fresh installion of POV, the problem persits further on (without
removing my own datas). ?? So I was not able to run all my scripts, I
created since the first installation.
What now ?. So I am running some PC`s (networked), at last I tried to start
POV from another PC (over the network, not installed at this one). And it
works! But that`s not a solution for my problem, because the station I want
to work with, is my Athlon 4000+ / Nvidia 6800 Ultra / Windows XP, Sp2 -
for better performance.
Any ideas from anybodie, what might going wrong?
Michael (Germany)
Subject: Re: big problem cmedit32.dll
Date: 23 Jul 2005 03:30:01
Message: <web.42e1f117f00ad4a9b1049cb0@news.povray.org>
"michael45" <nomail@nomail> wrote:
> Hi all,
> Michael (Germany)
07-22-05
.............oops! At last I could solve the problem by myself. From some
(very) strange reasons, an entry was found within the regestry - subsection
called OPEN. There has been set a path pointing to a subdirectory of POV,
including a filename *.pov (at the end of the line), which didn`t exist
more since the time, launching of POV has failed. After deleting this line
from the regestry - all works again.
As far as good. But, I would be very interessted about, what should do all
the poor people, beeing not familar with such internals? To keep the last
actions, settings etc. - during the use of any good programs - in some
*.ini files is normally and will done by POV as well.
But to write such settings in the regestry? Even after I deinstalled POV,
the regestry wasn`t cleaned properly - so after a fresh installation - the
problem hasn`t gone, unfortunately. Only after I started POV from a
networked PC (successfully) I got the idea - what might cause that problem.
Best regards to all
Michael (Germany)
