POV-Ray : Newsgroups : povray.general : POV-Ray and Radiosity Server Time
10 Sep 2025 14:34:47 EDT (-0400)
  POV-Ray and Radiosity (Message 1 to 5 of 5)
Subject: POV-Ray and Radiosity
Date: 28 Mar 2005 05:50:00
Message: <web.4247e0bb8480eb359e1e76f30@news.povray.org>
hi,
i'm new to POV-Ray, i'd like to use POV-Ray to make an image illustrating
radiosity. As i now, it seems that POV-Ray uses photon map for radiosity
but i need a method "radiosity"- i mean: it calculates form factors,.., is
it
possible to do that in POV-Ray ?
Thank in advanced :)
Subject: Re: POV-Ray and Radiosity
Date: 28 Mar 2005 06:14:18
Message: <4247e70a@news.povray.org>
Bui Nguyen Minh wrote:
> hi,
> it possible to do that in POV-Ray ?
   I think you should read *ASAP* section 2.3.4 (Radiosity), and perhaps
also 2.6.3 (Photons).
Jaime
Date: 28 Mar 2005 10:37:07
Message: <424824a3@news.povray.org>
Bui Nguyen Minh <bnm### [at] ifieduvn> wrote:
> hi,
> it
  No, povray does not use photon mapping for global illumination.
It uses a stochastic backward raytracing method first developed by
Greg Ward which is different from the photon mapping method and the
polygon algorithm generally called "radiosity".
  I guess that what you are looking for is the latter. The problem
is that that algorithm only works for polygon-based lightmapped
scenes and POV-Ray scenes are not limited to polygons but can use
all types of mathematical surfaces, thus that type of radiosity
cannot be used.
  The stochastic method used by POV-Ray is somewhat similar to
that "radiosity" algorithm, but it uses raytracing of semi-random
rays instead of scanline-rendering and can often produce visibly
different results.
Date: 28 Mar 2005 13:25:00
Message: <web.42484b64919cd944efc6e360@news.povray.org>
> > hi,
> > it
> cannot be used.
> different results.
Thank you very much for your help :)
One more question : is it possible to write a "plug-in" for povray to carry
out the latter ? if not, could you please tell me (in your opinion) what
should i do to carry out the latter? (using another render?, writing an
application?(using OpenGL?)...
Thanks again!
Date: 28 Mar 2005 15:03:44
Message: <42486320@news.povray.org>
> out the latter ?
  Plugin no, patch perhaps, but it would be quite limited as it would have
to be limited to meshes and bicubic patches (no other primitives could get
light from other surfaces nor affect the lighting) and it would be a
rather laborious task.
  There are many free simple scanline renderers out there which
demonstrate radiosity. Try google.
