POV-Ray : Newsgroups : povray.general : How to use the animation of POVRAY? Server Time
22 Nov 2025 05:15:37 EST (-0500)
  How to use the animation of POVRAY? (Message 1 to 10 of 11)
Subject: How to use the animation of POVRAY?
Date: 25 Feb 2005 12:25:00
Message: <web.421f5e4b476178e4c09c5d580@news.povray.org>
I learn the POVRAY only 3 weeks. Now, I want to make a program that use the
animation function. Can you tell me the way to use it? I look in the help,
but I can't find any.
Subject: Re: How to use the animation of POVRAY?
Date: 25 Feb 2005 13:17:58
Message: <stqu115msltu1bih8dvetvhpodbm4ct1j4@4ax.com>
On Fri, 25 Feb 2005 12:20:11 EST, "scorpmetal" <sco### [at] yahoocom>
In your Pov-Ray directory there are examples
C:\Graphics\POV-Ray for Windows v3.5\scenes\animations\
If you run and look at some of these you will get a good idea.
Run the INI file as this tells Pov-Ray how many frames to render and
the start and end value of the "clock" variable. In the POV file you
will use the "clock" variable to change something e.g. translate x* 5
* clock
Regards
Date: 25 Feb 2005 13:38:21
Message: <421f709d@news.povray.org>
the
See section "2.3.8  Making Animations." You can get there quickly by
pressing the "Scene" button (assuming you're using POV-Ray for Windows),
choosing the "index" tab, typing in "animation" and taking the first result.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 25 Feb 2005 14:50:38
Message: <421f818e$1@news.povray.org>
Darren New wrote:
> For what it's worth, when I was new to POV-Ray, it was confusing because
> nowhere did it actually say "POV-Ray doesn't make animations."  I think
> a paragraph at the top of that that says "POV-Ray doesn't make
> animations. But it can be configured to draw a bunch of sequential
> frames, based on the changing of "clock", so we now describe how to
> configure it that way" would possibly help.  It's a
> not-necessarily-obvious intuitive leap to get to "animations" from "INI
> for clock variable settings". :-)
Eh?  How is a bunch of sequential frames not an animation?
Tim Cook
Version: 3.12
Date: 25 Feb 2005 15:15:15
Message: <7m1v11piu5mfq9024r0drjj6ue5vgf1es7@4ax.com>
On Fri, 25 Feb 2005 14:50:34 -0500, Tim Cook <z99### [at] bellsouthnet>
You've forgotten what it's like to be young, Tim :-)
If Pov-Ray created animations, you wouldn't need an other programme to
put the frames together.
BTW what are the mdl's in Moray.b?
Regards
Date: 25 Feb 2005 15:36:48
Message: <421f8c60$1@news.povray.org>
standard-sided wall plates for a light switch and outlet.  figured i'd
share some of the basic components i've made.  i'll be making some
others as i get to needing to model them to put in the 3d model of my
reisdence on which i'm working.  figured people'd appreciate pre-made
standard architectural elements so's they can focus on modelling the
unique stuff...
Tim Cook
Version: 3.12
Date: 25 Feb 2005 15:40:18
Message: <421f8d32@news.povray.org>
  Perhaps you mean "POV-Ray doesn't create video files", which is a
completely different thing?
Date: 25 Feb 2005 16:39:32
Message: <lo6v111ubmnjqkc5vqetiaevangorpg217@4ax.com>
On Fri, 25 Feb 2005 15:36:44 -0500, Tim Cook <z99### [at] bellsouthnet>
>unique stuff...
Right, good idea. I did not recognize them as our switch plates are
square and the outlets have the sockets built in. Have you uploaded
them to the Moray site?
Regards
Date: 25 Feb 2005 16:46:14
Message: <421f9ca6@news.povray.org>
The 'upload.mdl' on the Moray site won't load in Moray 3.5...says it's
DOS only.  *shrug*
Tim Cook
Version: 3.12
Date: 26 Feb 2005 04:01:35
Message: <3ne021ho6j1jaknkr77gmn6mmt9gcfopg1@4ax.com>
On Fri, 25 Feb 2005 16:46:09 -0500, Tim Cook <z99### [at] bellsouthnet>
>DOS only.  *shrug*
That may explain why the Last update was: 29th October 2001
Someone should report it to Lutz (Hint :-)
Regards
