POV-Ray : Newsgroups : povray.general : HELP Using macro to visualise mathematical functions Server Time
16 Apr 2026 19:38:06 EDT (-0400)
  HELP Using macro to visualise mathematical functions (Message 1 to 6 of 6)
Subject: HELP Using macro to visualise mathematical functions
Date: 30 Nov 2004 12:30:01
Message: <web.41acadff91225dd755f15cf90@news.povray.org>
I would like to make a macro that visualises mathematical functions.
Something like this would be nice.
#macro MyFunc(Length,Formula)
#local N=0;
#while (N<=Length)
sphere { 0, 0.02
        pigment { rgb <N,0,N*-1+1> }
        translate <N,Formula,0>
#local N=N+0.1;
But as you might see this is of little use.
If this is to become usefull you have to be able to use it like this:
MyFunc(N*N)
In other words, you will have to be able to refere to the local N when you
call it, but it hasnt been defined yet.
If you try to define it before you call the macro it will calculate the
value before passing it into the macro.
Do I make any sense?
Is there any way you could get around this limitation?
Robb
Subject: Re: HELP Using macro to visualise mathematical functions
Date: 30 Nov 2004 13:04:57
Message: <41acb649$1@news.povray.org>
In article <web.41acadff91225dd755f15cf90@news.povray.org> , "The Ugly"
> MyFunc(N*N)
See <http://www.povray.org/documentation/view/3.6.1/231/>, in particular
2.2.1.6.2 Functions and Macros.
    Thorsten
Date: 30 Nov 2004 13:34:26
Message: <41acbd32$1@news.povray.org>
> <SNIP>
> MyFunc(N*N)
> when you call it, but it hasnt been defined yet. If you try to define
> it before you call the macro it will calculate the value before passing
> it into the macro.
No, you do not. Your MyFunc macro takes two parameters. What is 'N*N' in
MyFunc(N*N)? Are you trying to pass this as a 'Length' or a 'Formula'?
Looks like your 'Formula' just returns a 'y' value, so this might get
you started:
   #local N=0;
   #while (N<=Length)
     sphere { 0, 0.02
       translate <N,Formula(N),0> // this line is changed
     #local N=N+0.1;
MyFunc ( 10, function(x){x*x} )
// or try
// union{ MyFunc( 10, function(x){sin(x)} ) translate <-5,-3,0>}
// union{ MyFunc( 10, function(x){cos(x)} ) translate <-5,0,0>}
// union{ MyFunc( 10, function(x){sin(cos(x))} ) translate <-5,3,0>}
	location <0,0,-10>
	look_at 0
  -Shay
Date: 30 Nov 2004 13:49:07
Message: <uCYjsDAMCMrBFwjX@econym.demon.co.uk>
>#local N=0;
>#while (N<=Length)
>sphere { 0, 0.02
>#local N=N+0.1;
>#end
>#end
You've just made one tiny syntax error in that macro.
Here's a complete scene that works.
camera {location  <5,0,-20> look_at <5,0,0> angle 30}
background {rgb 1}
light_source {<-30, 100, -30> color rgb 1}
 #local N=0;
 #while (N<=Length)
  sphere { 0, 0.02
    translate <N,Formula(N),0>          // I changed this line
  #local N=N+0.1;
// Call it with length and one-dimensional function
MyFunc(10, function(n){sin(n)} )
Mike Williams
Gentleman of Leisure
Date: 30 Nov 2004 14:25:01
Message: <web.41acc8c098a169fb55f15cf90@news.povray.org>
Sorry, Im quite new to POV-Ray, and I know that I should read the
Documentation more. But I dont live in an English speaking country and Im
only 14 years old, all these mathematical terms can be quite hard to
undertand (lame excuse :p ).
Anyway, I made some last minute modifications before i posted the original
letter and I forgot to change "MyFunc(N*N)" to "MyFunc(1,N*N)" (or
whatever).
Thanks for the code Shay and Mike...this function-thing will simplify a lot
of my other scenes.
Just to set things straight: There is no way to sort of build in the
"function(n) { ... }" bit into the macro so that the user just has to type
"X*X" instead of "function(x) { x*x }" when calling it?
Date: 30 Nov 2004 15:09:48
Message: <41acd38c$1@news.povray.org>
There is, but the method is a bit ugly. There is a macro in
"strings.inc" called Parse_String. You can see how it works in the docs,
but in effect it turns a string (which can be passed as a macro
parameter) into the code inside the string. You can use it like this:
#include "strings.inc"
#local Formula = "x*x"; // notice that this is a string
#local TempFunction = function(x){ Parse_String(Formula) }
Another thing to watch out for is that function names cannot be reused
unless they are undefined first. So, if your macro is called more than
once, you will need to make sure that the declaration from the first
time is undeclared. This looks like this in POV-Ray:
#ifdef ( TempFunction )
   #undef TempFunction
Now the name TempFunction can be used again.
I'll let you figure out how to rewrite the macro. Let us know if you
need any help. Remember that the macro call will need the Formula as a
string. That is: MyFunc(1,"x*x")
  -Shay
