POV-Ray : Newsgroups : povray.general : "Surface based" refraction Server Time
1 Feb 2026 02:37:04 EST (-0500)
  "Surface based" refraction (Message 1 to 3 of 3)
Subject: "Surface based" refraction
Date: 13 Sep 2004 07:20:00
Message: <web.41458197ef55b98a313aa22d0@news.povray.org>
I'm having a little trouble getting the refraction of a glass pane right.
The refraction seems to be much to high given the ior value of the
material. A ior of 1.5 is normal for glass, but for me a value of 1.05
looks more like glass...
As an example I use what is supposed to be a glass pane with a thickness of
a few mm. Such a glass plane should not distort much. Maybe a little
paralell offset of the light (no more than the thickness of the glass).
But as you can see with my example, it distorts a "little more".
My assumption is that a solid glass pane can be modelled as two parallel
surfaces with opposite normal vectors. As the light refraction is
calculated when the light goes through each surface, this would act as a
solid object.
Am I wrong about this?
Please look at the example below. It it a little long, because it's
generated with a CAD program exporting to a .pov file. I've tried to take
away as much as possible:
(BTW: I'm using POV-Ray 3.5)
THE EXAMPLE:
global_settings
   assumed_gamma 2.2
   max_trace_level 8
   ambient_light 1
background { color rgb <1.0, 1.0, 1.0> }
camera
   location <5048.52, 2283.89, -5964.82>
   angle 28.34
   right <1.28,0,0>
   look_at  <2503.84, 280.51, -2575.62>
#declare T1 = texture
  uv_mapping
  pigment {checker color <0,0,0> color <1,1,1> scale 1}
  finish { ambient 0.70 diffuse 0.70 phong 0.70 phong_size 176 reflection
0.07 }
mesh2
  vertex_vectors
   4,
   <1000.0,0.0,-1000.0>,
   <3600.0,0.0,-1000.0>,
   <3600.0,0.0,-3200.0>,
   <1000.0,0.0,-3200.0>
  normal_vectors
   1,
   <0.000,1.000,0.000>
  uv_vectors
   4,
   <0.000,0.000>,
   <0.000,8.667>,
   <7.333,8.667>,
   <7.333,0.000>  }
  face_indices
   2,
   <2,1,0>,
   <3,2,0>
  normal_indices
   2,
   <0,0,0>,
   <0,0,0>
  uv_indices
   2,
   <2,1,0>,
   <3,2,0>
  texture
   T1
#declare T3 = texture
  pigment { rgbt <1.00, 1.00, 1.00, 0.93> }
  finish { ambient 0.70 diffuse 0.70 phong 0.10 phong_size 25 refraction 1
ior 1.5 }
mesh2
  vertex_vectors
   4,
   <3300.0,0.0,-2880.0>,
   <3300.0,1000.0,-2880.0>,
   <2300.0,1000.0,-2880.0>,
   <2300.0,0.0,-2880.0>
  normal_vectors
   1,
   <0.000,0.000,1.000>
  face_indices
   2,
   <2,1,0>,
   <3,2,0>
  normal_indices
   2,
   <0,0,0>,
   <0,0,0>
  texture
   T3
mesh2
  vertex_vectors
   4,
   <2300.0,0.0,-2900.0>,
   <2300.0,1000.0,-2900.0>,
   <3300.0,1000.0,-2900.0>,
   <3300.0,0.0,-2900.0>
  normal_vectors
   1,
   <0.000,0.000,-1.000>
  face_indices
   2,
   <2,1,0>,
   <3,2,0>
  normal_indices
   2,
   <0,0,0>,
   <0,0,0>
  texture
   T3
Subject: Re: "Surface based" refraction
Date: 14 Sep 2004 04:58:41
Message: <4146b2c1@news.povray.org>
There seems to be some strange peculiarity with meshes in this regard.
I tried making one single mesh from the two "glass" meshes and then it
works just ok. Seemingly there's some problem in having your glass object
consisting of two separate meshes...
global_settings
   assumed_gamma 2.2
   max_trace_level 8
   ambient_light 1
camera
   angle 28.34
   right <1.28,0,0>
  uv_mapping
0.07 }
mesh2
  vertex_vectors
   4,
  normal_vectors
   1,
   <0.000,1.000,0.000>
  uv_vectors
   4,
   <0.000,0.000>,
   <0.000,8.667>,
   <7.333,8.667>,
   <7.333,0.000>  }
  face_indices
   2,
   <2,1,0>,
   <3,2,0>
  normal_indices
   2,
   <0,0,0>,
   <0,0,0>
  uv_indices
   2,
   <2,1,0>,
   <3,2,0>
  texture
   T1
  finish { ambient 0.70 diffuse 0.70 phong 0.10 phong_size 25 //refraction 1 ior 1.5
mesh2
  vertex_vectors
   8,
   <2300.0,0.0,-2880.0>,
  normal_vectors
   2,
   <0.000,0.000,1.000>,
  face_indices
   4,
   <3,2,0>,
   <2,1,0>
   <6,4,5>,
   <7,4,6>
  normal_indices
  { 4,
    <0,0,0>,
    <0,0,0>,
    <1,1,1>,
    <1,1,1>
  texture
   T3
  interior { ior 1.5 }
Date: 14 Sep 2004 09:45:00
Message: <web.4146f5c75ba49a37313aa22d0@news.povray.org>
> global_settings
>    assumed_gamma 2.2
>    max_trace_level 8
>    ambient_light 1
> camera
>    angle 28.34
>    right <1.28,0,0>
>   uv_mapping
> 0.07 }
> mesh2
>   vertex_vectors
>    4,
>   normal_vectors
>    1,
>    <0.000,1.000,0.000>
>   uv_vectors
>    4,
>    <0.000,0.000>,
>    <0.000,8.667>,
>    <7.333,8.667>,
>    <7.333,0.000>  }
>   face_indices
>    2,
>    <2,1,0>,
>    <3,2,0>
>   normal_indices
>    2,
>    <0,0,0>,
>    <0,0,0>
>   uv_indices
>    2,
>    <2,1,0>,
>    <3,2,0>
>   texture
>    T1
> mesh2
>   vertex_vectors
>    8,
>   normal_vectors
>    2,
>   face_indices
>    4,
>    <3,2,0>,
>    <2,1,0>
>    <6,4,5>,
>    <7,4,6>
>   normal_indices
>   { 4,
>     <0,0,0>,
>     <0,0,0>,
>     <1,1,1>,
>     <1,1,1>
>   texture
>    T3
Thanks! This did the trick!
-Rune
