POV-Ray : Newsgroups : povray.general : Punching a hole in a height field Server Time
21 Feb 2026 09:55:25 EST (-0500)
  Punching a hole in a height field (Message 1 to 5 of 5)
Subject: Punching a hole in a height field
Date: 27 May 2004 07:40:01
Message: <web.40b5d2679f50c2a518134edd0@news.povray.org>
I have a height field I'm using as a mountain from the outside, and a cave
from the inside.
What I want to do is punch a hole in the heightfield so I can stand inside
and look out, or vice-versa.
I tried
#declare mountain = difference
   object <the height field>
   object <a box that spans the skin of the height field>
but I don't seem to be able to see beyond the skin of the box, which I can
see projecting into the cave.
What am I doing wrong??
Subject: Re: Punching a hole in a height field
Date: 27 May 2004 09:45:00
Message: <web.40b5ef9eb88e3b7d18134edd0@news.povray.org>
> from the inside.
> I tried
Well.... I answered it myself.  I made the box pigment {rgbt<1,0,0,1>}. I
now have a tunnel through from inside to outside.
But, in a totally different example, if I'd taken a box, and drilled through
it with a cylinder ie difference{box{} cylinder{}}, I wouldn't have had to
make the cylinder transparent.
Why?
Date: 27 May 2004 13:36:46
Message: <mklFHDAcaitAFw1Y@econym.demon.co.uk>
>> from the inside.
>> I tried
>Why?
As far as I can see difference{box{} cylinder{}} works exactly the same
way as difference{height_field{} box{}}.
If I understand what you're trying to achieve, you should be doing is
height_field{clipped_by{box{}}}.
Mike Williams
Gentleman of Leisure
Date: 27 May 2004 13:45:01
Message: <eUqL7EAjjitAFwRH@econym.demon.co.uk>
Sorry, I meant to say
height_field {clipped_by {box {} inverse}}}
Mike Williams
Date: 1 Jun 2004 05:00:00
Message: <web.40bc454cb88e3b7d18134edd0@news.povray.org>
> Mike Williams
Aaahh... Thanks.  I'll have a look at clipped_by.
