![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I have a height field I'm using as a mountain from the outside, and a cave
from the inside.
What I want to do is punch a hole in the heightfield so I can stand inside
and look out, or vice-versa.
I tried
#declare mountain = difference
object <the height field>
object <a box that spans the skin of the height field>
but I don't seem to be able to see beyond the skin of the box, which I can
see projecting into the cave.
What am I doing wrong??
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> from the inside.
> I tried
Well.... I answered it myself. I made the box pigment {rgbt<1,0,0,1>}. I
now have a tunnel through from inside to outside.
But, in a totally different example, if I'd taken a box, and drilled through
it with a cylinder ie difference{box{} cylinder{}}, I wouldn't have had to
make the cylinder transparent.
Why?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> from the inside.
>> I tried
>Why?
As far as I can see difference{box{} cylinder{}} works exactly the same
way as difference{height_field{} box{}}.
If I understand what you're trying to achieve, you should be doing is
height_field{clipped_by{box{}}}.
Mike Williams
Gentleman of Leisure
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Sorry, I meant to say
height_field {clipped_by {box {} inverse}}}
Mike Williams
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Mike Williams
Aaahh... Thanks. I'll have a look at clipped_by.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
