POV-Ray : Newsgroups : povray.general : Lotsa Photons (Literally!) Server Time
23 Nov 2025 01:55:17 EST (-0500)
  Lotsa Photons (Literally!) (Message 1 to 7 of 7)
Subject: Lotsa Photons (Literally!)
Date: 21 May 2004 10:30:01
Message: <web.40ae1177d70920a7945ad0900@news.povray.org>
Hello
Here is the problem in it's briefest form.
I set POV-Ray rendering on a scene with photons and left it for about 7
hours.
When I came back I saw that it hadn't even started rendering yet, it was
just building photon maps.
Now this is the problem: It had built a photon map of about 1,500,000,000
photons. I stopped it at this point and looked through the code but I
couldn't see anything wrong. I tried running it again, but watched it this
time. After about 10 seconds it started rendering, but I hadn't changed any
code at all.
Why did this happen? Please tell me.
Thanks in advance!
Subject: Re: Lotsa Photons (Literally!)
Date: 21 May 2004 13:40:21
Message: <40ae3f05$1@news.povray.org>
<nomail@nomail> wrote in message
news:web.40ae1177d70920a7945ad0900@news.povray.org...
> Hello
> hours.
any
> code at all.
> Thanks in advance!
are you explicitly using "count" in photon global settings, or are you using
"spacing"? count will limit the number of photons, and spacing will use as
many as it needs(?). that's my naive understanding. i always use count.
http://www.povray.org/documentation/view/209/
Date: 21 May 2004 13:44:34
Message: <40ae4002@news.povray.org>
> any
> > code at all.
hah. glossed over this part of your message. nevermind my "count versus
spacing" message. though it might somehow be related, indirectly... or
something ;)
Date: 21 May 2004 18:53:14
Message: <40ae885a@news.povray.org>
  You have to specify "photons { target }" only in those objects which
are reflecting/refracting (and which you want to have caustics) and these
objects must not be infinite (such as planes).
  You do not specify "photons { target }" for objects which are not
reflecting/refracting nor those which are infinite. (If you *really*
need photons to be directly shot at an infinite object, you'll have
to make it finite by manually specifying a bounding box for it.)
  Having an infinite object being the target for photons is one reason
for the photon calculations to take forever.
Date: 23 May 2004 13:55:48
Message: <cjameshuff-286B3F.12561123052004@news.povray.org>
In article <40ae885a@news.povray.org>, Warp <war### [at] tagpovrayorg>
But note in this case that it is an intermittent problem...not a problem
with the scene, but a bug somewhere. Something's either uninitialized or
getting written over. Unfortunately, finding it is likely to be very
difficult...the problem can be literally anywhere, and will behave
differently on different machines. It might even be a bad piece of RAM
in the affected system...but I think other people have reported similar
things.
http://tag.povray.org/
Date: 24 May 2004 09:08:35
Message: <40b1f3d3@news.povray.org>
  What do you mean?
  Certainly the photon code could be *improved* (eg. by adding a code
which refuses to take an infinite object as a target), but I don't
understand how it is buggy or system-dependant.
Date: 24 May 2004 13:22:22
Message: <cjameshuff-D69584.12224824052004@news.povray.org>
In article <40b1f3d3@news.povray.org>, Warp <war### [at] tagpovrayorg>
From the original message:
"I tried running it again, but watched it this time. After about 10
seconds it started rendering, but I hadn't changed any code at all."
It spent over 7 hours collecting over a billion photons before being
canceled. The next time, it spent a few seconds and rendered as it
should have. That sort of nondeterministic behavior is almost always a
sign of a bug.
And it shouldn't disallow infinite objects as photon targets...finite
objects can take just as long, if their bounding box contains the light
source. However, a warning may be in order for both these cases.
