POV-Ray : Newsgroups : povray.general : POV-Ray and physical simulation Server Time
31 Mar 2026 09:57:00 EDT (-0400)
  POV-Ray and physical simulation (Message 1 to 10 of 12)
Subject: POV-Ray and physical simulation
Date: 21 Sep 2003 07:05:01
Message: <web.3f6d83d878e5ce8fa6e5cfad0@news.povray.org>
Greetings!
I have been using POV-Ray for graphical work
for a couple of years, and am truly impressed
with the functionality and flexibility of the program.
Becoming more and more fascinated with the
potential of ray-tracing in general and POV-Ray
in particular, I have lately started pondering on
the possibility of integrating physics simulation
in the software - a new step towards the ultimate
realism that computer grapics as an art form
seems to strive for.
I am aware of some tendencies in this direction,
e. g. simulation of gravity in particle generators.
But have there been any systematic and organized
programming initiatives? It would of course be
a tremendous undertaking, but a glorious one as
well - turning POV-Ray into a general phenomeno-
logical and physical software rather than just an
application for making pretty pictures.
(I am not a programmer myself, so regard this as
a question born out of pure curiosity. Although I
realize the enormous complexity of the proposed
task, I can't help but being... well, swept away by
the thought of what lies ahead!)
Subject: Re: POV-Ray and physical simulation
Date: 21 Sep 2003 08:10:02
Message: <3f6d951a@news.povray.org>
You might want to take a look at Christoph
Hormann's "Mechsim", or at the latest MegaPOV
release, in which it is incorporated.
Creating an inbuilt physical simulation algorithm
with other techniques than that seems to me
quiet impossible. Other than Polygon-Based
renderers, POV-Ray doesn't have many
object-nodes on which calculations may
be based, surfaces aren't easily defined as with
polygons. In effect, it becomes quiet difficult
to properly have for example a sphere and
a box interact, it gets even more complicated
with CSG, hollow objects, mass etc.
The problem with scripting them into the core
of POV-Ray is that most of the time, several
approaches exist, and they might be quiet
contradictory in setting them up. AFAIK,
POV-Ray 4 (which is a long way off, and
don't think about asking about it: it's finished
when its finished, as always with POV-Ray,
and I don't object) should have better support
for plug-ins (in other words: other support
than just POV-Script Include-Files) in order
to make writing own enhancements easier
and faster (as POV-Script is quiet slow).
Maybe you'd want to write a mesh-based
physical simulation in C++, and the output
of that can be used for POV-Ray to
render. Several programs have been done
that way.
Tim
Tim Nikias v2.0
Email: no_lights (@) digitaltwilight.de
> Greetings!
Version: 6.0.518 / Virus Database: 316 - Release Date: 11.09.2003
Date: 22 Sep 2003 08:00:01
Message: <web.3f6ee3cf169a70a1b317dc110@news.povray.org>
Tim Nikias v2.0 wrote:
>You might want to take a look at "Mechsim".
>quite impossible.
>POV-Ray 4 should have better support
>for plug-ins.
Mechsim is certainly a great piece of code,
and I have had a brief look at it, although
I haven't used it in any of my own projects
as of yet. But what I have in mind goes far
beyond just basic mechanics simulation. For
instance, consider the differece in lights
and rendering between POV-Ray and Radiance:
whereas POV simply uses a color float to
specify the intensity and hue of a light
source, Radiance takes a different approach,
specifying the lights in a more scientific
way. I imagine that such an approach could
be taken a lot further, though. For instance:
working with solid volumes (in the simulation,
of course - it would be pointless in the actual
rendering) rather than surface-based objects
with insides and outsides; specifying materials
in terms of elements and their characteristics,
such as density, surface properties and so on,
thus incorporating pigment, normal and media
statements into a single grammar based in
chemistry and - ultimately, but still far out
of reach - particle physics; define groups of
objects as "organisms", interacting according
to kinematics, evolutionary algorithms, etc.
Even if it was possible, it probably wouldn't
be worthwile to incorporating such a diverse
set of functions into the core of POV-Ray, and
better support for plugins is always a good
thing, of course. But adapting the program to
scientific definitions and terminology in more
respects than just the optical is a prerequisite
for making the plugin system coherent from a
conceptual viewpoint.
(You should consider all of this as musings
of a speculative mind with heavy utopian
leanings, thinking beyond all restraints of
actual computing power - I run POV on a puny
32 Mb RAM! My interest lies primarily in the
discussion: the potential of simulation, not
the actual state of affairs.)
Date: 22 Sep 2003 10:21:07
Message: <3f6f0553@news.povray.org>
Althouth the Utopian Idea of defining
Objects via chemistry-based, scientific
properties like density, viscosity, termal
reaction etc would go way beyond
anything a normal User would achieve,
it is interesting. I mean, who would actually
go create the reflective sphere with a
checkered plane, using lead, different
sets of marble, and go look up their
proper values?
What you're actually proposing is something
like a world-simulation, which should take
all known physical behaviours into account.
Problem with that is, that there are sometimes
quiet a diversity of approaches on how to
model and accurately put things into values.
Just take the different color-models,
RGB, which POV-Ray uses, is only one, and
there are several out there which may be of
better use for certain tasks.
I think a less Utopian Approach would be to
model different but specialized simulations. E.g.
one for fire, another for liquids, mass-particle
effects, with and without particle-interaction,
lighting models...
Once a basic setup is chosen (like: what of a
lightray is saved and handed down the recursive
tree: direction, reflection-points, intensity, color,
etc?), Plug-Ins should make use of different
properties and enhance/replace them. As for
simulations themselves (heat, for example), the
scene has to be preparsed somehow (at least
I'd expect that, using voxels or such), and then
the heat-simulation would run by itself. Introducing
a cold liquid? The liquid simulation takes care of
"being liquid", but the the heat-simulation reads
where the liquid is going and simulates heat-
properties for it. Combining both would make
it more difficult to properly set things up.
Just take my LSSM, the Liquid-Surface-Simulation-
Macros, as an example. They're only of use for
areas where the water is in an enclosed space, like
a pond, a swimming pool, or such. They create
near-realistic effects for waves. Aside of that, they
can't be used to simulate a burst of water into
a tunnel. Its just the surface. IMHO, taking care
of small parts, and combining them in the end, is
better, than having a huge, combined simulation,
where certain parts may be really redundant.
Tim Nikias v2.0
> >quite impossible.
> >for plug-ins.
Version: 6.0.520 / Virus Database: 318 - Release Date: 18.09.2003
Date: 22 Sep 2003 14:59:46
Message: <cjameshuff-B8A764.14575322092003@netplex.aussie.org>
In article <3f6d951a@news.povray.org>,
 "Tim Nikias v2.0" <no_lights (@) digitaltwilight.de> wrote:
>  AFAIK,
And where did you hear this?
As you say, it's a long way off, too far off to say anything definite
about plugin support. However, historically, native plugin support has
never been implemented because there is no platform-independant way of
doing it. POV could use precompiled bytecode plugins instead, but then
there's no reason not to just include the source files: the bytecode
compiler could (and almost certainly would) be built into POV. The
current scripting language is slow because it is interpreted directly,
compiling to bytecode first can be much faster, and would work just fine
with the current system of include files.
http://tag.povray.org/
Date: 22 Sep 2003 15:11:23
Message: <3f6f495b@news.povray.org>
I've heard rumours, so that's the reason for a
"AFAIK". I don't know who originally mentioned
it, and perhaps it was just a discussion amongst
those not able to program POV themselves, but
what they would like to see. Not sure.
Still, even a faster compiler could count as
being Plug-In Support. I was just thinking
in terms of Cinema4D, Maya and such, where
"outside" scripts can be used quiet efficiently to
enhance the GUI (although POV doesn't really
have its own one, but a Free Script Editor,
right? I mean, its not programmed by the
POV-Team, is it?) and modelling aspects.
The Include-Files of today may count as
plug-ins, but getting something which may make
them parse faster (more like bytecode, as
you mentioned, or easier handling as external
programms to be called inbetween frames) would
be very much appreciated (at least by me, I
tend to write these huge parsing-intensive scripts...).
Other than POV 4 being a dream, there is no
actual code there yet, is there? I mean, gathering
feature-ideas and such is in progress, perhaps
even spending some thought in how to go
about it, but no real code?
Tim Nikias v2.0
> >  AFAIK,
> Christopher James Huff <cja### [at] earthlinknet>
> http://home.earthlink.net/~cjameshuff/
> POV-Ray TAG: chr### [at] tagpovrayorg
Date: 22 Sep 2003 15:30:36
Message: <o5jumvorjk0n0n3nct1lir5m6ep3eoolq4@4ax.com>
On Mon, 22 Sep 2003 21:06:04 +0200, "Tim Nikias v2.0" <no_lights (@)
Every small step between start and finish is a progress :-)
This includes every new include file, every insert menu, every tested feature
in own patch, every typo found in documentation.
ABX
Date: 22 Sep 2003 15:52:02
Message: <l90441-834.ln1@triton.schunter.etc.tu-bs.de>
> POV-Team, is it?)
You do realized that Cinema4D and Maya as well as the WinPOV GUI are not
platform independant (both Cinema4D and Maya are available for multiple
platforms but only through a lot of platform specific work you can bet).
Any 'plugin' feature in POV 4 will probably have much more similarity to
  POV-Ray 3.5 user defined functions and POVMan shaders than to a plugin
system you might know from another program.
Last updated 2 Sep. 2003 _____./\/^>_*_<^\/\.______
Date: 22 Sep 2003 16:05:25
Message: <3f6f5605@news.povray.org>
I know that GUI wouldn't be the perfect
example...
But take my LSSM, or Rune's and my
particle system. If one could easily set
things like
"lssm_simulation_steps" in global-settings,
and then have some object like
lssm_rectangle{ Corner_1, Corner_2, Corner_3}
and *additionally* have them parse faster,
by just putting a pre-parsed bytecode in
some directory for POV-Ray to find
it, that would be neat! Right now one has
to include the files, and they don't have
much access to POV-Internal stuff like
rays for lighting calculations and such.
For platform-independance, I guess a
faster parser could be quiet sufficient,
but some more object-oriented style
would be nice. E.g. macro's with same
name, but if I leave out a texture, it
will still work:
#macro Tex_Translate(Position,Texture)
 texture{Texture translate Position}
#macro Tex_Translate(Texture)
 texture{Texture}
#macro Tex_Translate(Position)
 texture{Default_Texture translate Position}
This would require POV to understand the
difference of vectors/floats/textures/objects
etc for parameters, but that would make some
handling easier.
All in all, I'm no expert on this, but a
functionality which would writing own
camera-functions like Slime (if I'm not
mistaken) did, or how the original isosurface
made it into MegaPOV, easier, without
compiling your own POV-Version, that
would be great.
But I'm probably annoying you with
my ignorant rambling, its just a dream
of mine... ;-)
Tim Nikias v2.0
> > POV-Team, is it?)
> Christoph
> POV-Ray tutorials, include files, Sim-POV,
> HCR-Edit and more: http://www.tu-bs.de/~y0013390/
Date: 22 Sep 2003 16:50:00
Message: <Xns93FEE845BA122seed7@netplex.aussie.org>
> will still work:
> #end
Something like this?:
http://www.python.org/doc/current/tut/node6.html#SECTION0067100000000000
00000
4.7 More on Defining Functions and further
(there may be a few zeros broken off that link)
Regarding speed, when I made my param.inc file I also did it in python.
The original param.inc only used macros and was quite a bit slower that
its Python equivalent. After rewriting param.inc to using functions the
parse time of both seemed the same at first sight, but SDL was actually
faster. In the same time it took to run the python program, SDL did the
same calculations and also parsed a million triangles. The resulting
file generated by python still had to be read and parsed by POV-Ray
then. So SDL isn't that bad in all cases. In one of the old MegaPOV
versions is a patch for speeding up macros that also helped a lot. And
when I see the speeds that can be reached with for example the
'interpreted' version of ocaml, there must still be some room for
improvement somewhere.
Regarding plugins, why do so many people want these and why do so few
people suggest going in the "opposite way". Chop POV-Ray in two/three
pieces, a raytracing libray (+parser) +API and have the SDL as its prime
implementation. Then everybody could write their scenes in any language
somebody generated a binding for. You could even plug POV-Ray into one
of the big 3D apps, although you probably could do now too if somebody
wrote the stuff that is needed inbetween.
All the above is offcoarse written without being hamperd by any
knowledge of the matter.
Ingo
