POV-Ray : Newsgroups : povray.general : Creating a text object from a variable... Server Time
20 Apr 2026 12:45:15 EDT (-0400)
  Creating a text object from a variable... (Message 1 to 5 of 5)
Subject: Creating a text object from a variable...
Date: 20 Aug 2003 01:00:01
Message: <web.3f42fe6a489b556e39b4d5c90@news.povray.org>
I'm trying to make a grid system to help with placement (which will be
commented out for the final renderings, of course) but I have no idea how
to do the numbers without having to do them all by hand.
I thought there would be a way to get it to print out the value of the Count
variable, but that's not turning out too well.
Subject: Re: Creating a text object from a variable...
Date: 20 Aug 2003 03:10:44
Message: <1fzzdc8.c9ovi61xl16bcN%kaveh@delete_this.focalimage.com>
Str() should do it. See documentation, 6.1.7.1.
Kaveh
Date: 21 Aug 2003 00:20:01
Message: <web.3f4445ee3750c9862db2e4420@news.povray.org>
I've tried that, but I keep getting an error message. I don't have easy
access to the program now, but something to do with numbers expected or
something like that.
>Kaveh
Date: 21 Aug 2003 02:36:24
Message: <3f446868@news.povray.org>
"dwmitch" <nomail@nomail> wrote in message
news:web.3f4445ee3750c9862db2e4420@news.povray.org...
Try something like:
#local IterateX=4/3; // 1.333333
text {
 ttf "arial.ttf"
// variable identifier, minimum length, decimal places
 str(IterateX,0,0),
 0,0 // depth, offset
 pigment {rgb 1}
Date: 21 Aug 2003 04:48:50
Message: <3f448772@news.povray.org>
  A short code demonstrating the error you are getting would be very
helpful.
