POV-Ray : Newsgroups : povray.general : Bug when using radiosity with invisible objects Server Time
3 Mar 2026 10:53:58 EST (-0500)
  Bug when using radiosity with invisible objects (Message 1 to 4 of 4)
Subject: Bug when using radiosity with invisible objects
Date: 14 Apr 2003 05:20:04
Message: <web.3e9a7cdda9729e92bef0bd7d0@news.povray.org>
I think there is a bug when using radiosity with invisible objects.
Radiosity don't work when I use no_image in my objects!
Any suggestions how can I render my scene correctly?
Matti
Subject: Re: Bug when using radiosity with invisible objects
Date: 14 Apr 2003 05:24:49
Message: <9evk9vg4po9tn7jnihrkge262176vl5j1u@4ax.com>
What you mean in "don't work" ? The scene is not rendered at all ?
Have you seen in documentation: "When no_image is used, the object will not be
seen by the camera, either directly or through transparent/refractive objects.
However, it will still cast shadows, and show up in reflections (unless
no_reflection and/or no_shadow is used also)."
Did this sentence helped you ?
ABX
Date: 14 Apr 2003 06:40:03
Message: <web.3e9a8ee2b9728b06bef0bd7d0@news.povray.org>
Scene will render but radiosity effects from invisible objects are missing.
If I don't use no_reflection then I assume that object is still there and
it can be seen indirectly from reflections. Like from mirror, photons or
diffuse interreflections.
Matti
Date: 14 Apr 2003 08:48:42
Message: <3e9aae2a@news.povray.org>
In article <web.3e9a8ee2b9728b06bef0bd7d0@news.povray.org> , "Matti
No, that is an incorrect assumption and ABX quoted the section in the manual
that explains how it does work.
    Thorsten
e-mail: tho### [at] trfde
