POV-Ray : Newsgroups : povray.general : Black artifacts when rendering isosurfaces Server Time
3 Mar 2026 18:04:10 EST (-0500)
  Black artifacts when rendering isosurfaces (Message 1 to 4 of 4)
Subject: Black artifacts when rendering isosurfaces
Date: 16 Jan 2003 18:50:03
Message: <web.3e274424fd4d5f76802871ed0@news.povray.org>
I have a very simple isosurface described by the following POV code:
isosurface {
        function {y - sin(x)}
 threshold 0
 open
 contained_by {sphere {<0, 0, 0>, 4}}
  pigment {color rgb < 1, 0.9, 0.65>}
  finish {
   brilliance 1.6
   specular 0.3
It is essentially a round disk with sinusoidal waves in it.
However, when viewed from different angles the surface, instead of being s
smooth surface, it often has many black pixels and curved black lines
rendered across the surface.
I have tried rendering with AA on (which reduces their appearance a little)
and by setting much higher accuracies for the isosurface (which also
reduces the effect, but does not remove it).
Can anyone tell me if this is a known issue with isosurfaces? It seems to me
this particular case is a very simple surface and should not present the
renderer with significant problems.
I am using the POV 3.5 final release binaries.
Cheers,
Raymond.
Subject: Re: Black artifacts when rendering isosurfaces
Date: 16 Jan 2003 19:24:14
Message: <3e274d2e@news.povray.org>
Please post a *complete* (but minimal) scene which *shows the problem*.
It's a lot of trouble if we have to find the camera and light locations
for ourselves.
  Just one question: Does POV-Ray give you any warning when you see the
artifacts?
Date: 16 Jan 2003 19:40:03
Message: <web.3e27502953e3fea0802871ed0@news.povray.org>
>for ourselves.
>artifacts?
Sorry! Here's the complete code for an animation that shows the effect quite
graphically, but it's small :-)
// Persistence Of Vision raytracer version 3.5 sample file.
#include "stdinc.inc"
#include "arrays.inc"
#version 3.5;
global_settings {
 assumed_gamma 1
sky_sphere {
 pigment {gradient y
  color_map {
   [0 color Blue*0.6]
   [1 color White]
#declare CamLoc = < 0, 5, -10>;
 location CamLoc
 angle 45
 look_at <0, 0, 0>
light_source {<-20, 30, -30>*3 color White*1.5}
light_source {CamLoc color rgb 0.3}
#declare Ground =
isosurface {
        function {y - sin(x + clock * 2 * 3.14159265) }
 threshold 0
 open
 all_intersections
        accuracy 0.000001
  normal {granite 0.2 scale 0.02}
  finish {
   brilliance 1.6
   specular 0.3
object {Ground rotate (clock * 360)*y}
And.. ack! Yes POV does throw a warning about the iso-surface, it was buried
in all the other stuff flying past so I didn't notice it:
Warning is:
Warning: The maximum gradient found was 1.163, but max_gradient of the
isosurface was set to 1.100. The isosurface may contain holes!
Adjust max_gradient to get a proper rendering of the isosurface.
I have increased max_gradient appropriately and now it works fine! Might be
nice if POVRay put such warnings a little more 'in your face' :-)
Thanks for the hint!
Cheers,
Raymond.
Date: 17 Jan 2003 04:53:45
Message: <3e27d2a9$1@news.povray.org>
"Raymond" <ray### [at] trimbleconz> wrote in message
news:web.3e27502953e3fea0802871ed0@news.povray.org...
Don't worry - you'll get used to it, and in the meantime that's what we're here
for....
