POV-Ray : Newsgroups : povray.general : transparency methods Server Time
31 Dec 2025 14:17:51 EST (-0500)
  transparency methods (Message 1 to 3 of 3)
Subject: transparency methods
Date: 4 Dec 2002 04:15:04
Message: <web.3dedc620652b014fc571aa6c0@news.povray.org>
Could POVray have some new transparency methods added to it? The existing 2
don't meet all needs.
One kind of transparency that would be good would be the kind where when you
use a greyscale map, the black is invisible, the white is opaque, and the
shades inbetween brighten up what is viewed behind the transparent object.
This would be good for making lens flares, as my experiments using transmit
haven't looked very good. The inbetween transparent areas look slightly
grey. I am using varying transparency, going from 1 at black to 0 at white.
I can't seem to figure out any solution to this other than having a new
transparency method added to the program.
Rohan _e_ii
Subject: Re: transparency methods
Date: 4 Dec 2002 04:45:10
Message: <Xns92DA6E49DDB41seed7@povray.org>
in news:web.3dedc620652b014fc571aa6c0@news.povray.org Rohan Bernett
wrote:
> ... and the
> object.
Have you tried transmit values bigger than 1 ?
Seee the demoscene bwstripe.pov
Ingo
Date: 4 Dec 2002 05:38:49
Message: <hlmruuc55smb149quk2n4ljc6dns4cepm3@4ax.com>
On Wed,  4 Dec 2002 04:08:48 EST, "Rohan Bernett" <rox### [at] yahoocom>
That's simply because you don't know how to use all their
possibilities.
Use a pigment_map using an image_pattern and transmit values greater
than 1.
If you really think so, go ahead and add one :) Me, I'll stick with
what there is as it can perfectly well do what I want it to do.
Peter Popov ICQ : 15002700
