POV-Ray : Newsgroups : povray.general : Light source inside object/CSG warnings? Server Time
11 Sep 2025 15:34:52 EDT (-0400)
  Light source inside object/CSG warnings? (Message 1 to 7 of 7)
Subject: Light source inside object/CSG warnings?
Date: 20 Mar 2000 19:09:53
Message: <slrn8ddf64.2mf.sjlen@zero-pps.localdomain>
I've got an object and I want a lightsource inside it,
so I used:
union{
      object{Whatever .....}
      light_source{<0,0,0>
                   color rgb 0.5
or even:
union{
      object{
                          color rgb 0.5
With either of these I get a warning that a CSG should have more than
one object. So in order to make the warning go away I've tried:
                   color rgb 0.5
      }  // End of object.
This won't render I get an error message telling me that I must use
the new syntax.
So if someone could tell me how to get rid of the warnings or what
the new syntax is I'd be grateful.
 11:48pm  up 1 day, 20:22,  7 users,  load average: 2.06, 1.57, 1.31
Subject: Re: Light source inside object/CSG warnings?
Date: 20 Mar 2000 19:24:12
Message: <38D6C189.4494AED4@pacbell.net>
> so I used:
> the new syntax.
The new syntax warning means do not declare your light_source as an
object use instead -
             color rgb 0.5
            } // End of light_source.
Since a light source is not considered an object in POV-Ray it does
not count as one in a csg operation. Ignore the warnings and it will
work anyway.
Date: 20 Mar 2000 19:24:43
Message: <38D6C8B0.73A9C56E@merlin.net.au>
You could try
light_source{
  <0,0,0>
  rgb 0.5
  looks_like{ some_object }
This effectively makes a union of the light_source and the object.
PoD.
Date: 20 Mar 2000 19:51:01
Message: <slrn8ddh46.2s5.sjlen@zero-pps.localdomain>
On Mon, 20 Mar 2000 16:25:45 -0800, Ken wrote:
>> so I used:
>> the new syntax.
>             color rgb 0.5
>work anyway.
Man that was fast.  Guess I'll just have to live with the warnings
then.
Pod suggests using a looks_like, but for some reason I hate the
looks_like statement with a passion.
Thanks.
 12:27am  up 1 day, 21:02,  6 users,  load average: 1.14, 1.14, 1.10
Date: 21 Mar 2000 04:33:25
Message: <38d741e5@news.povray.org>
Steve <sjl### [at] ndirectcouk> wrote:
: Pod suggests using a looks_like, but for some reason I hate the
: looks_like statement with a passion.
  There's nothing to hate about the looks_like. It however works differently
from an union.
  Firstly it implicitly makes the object shadowless.
  Secondly it translates the object with the location of the light.
Date: 24 Mar 2000 12:25:28
Message: <slrn8dn6vn.864.sjlen@zero-pps.localdomain>
>from an union.
That's why I hate it, I had some quite bad early experiences with it,
mainly not being able to predict where the hell the thing would be,
I've played with it a lot but don't seem to be able to master it.
I've used looks_like in the title images on my web page, but can't
tell quite what it's doing, the images look good to me so I've left
the looks_like in there, I've tried moving it around, but nothing
seems to move, so I've vowed never to use them again.
  4:40pm  up 5 days, 13:14,  6 users,  load average: 1.03, 1.14, 1.19
Date: 24 Mar 2000 13:15:05
Message: <38dbb0a9@news.povray.org>
No problem.
light_source
{ 0,1
  looks_like { whatever }
  translate <1,2,3>
