POV-Ray : Newsgroups : povray.general : more interesting functions is isosurface Server Time
1 Oct 2024 00:08:40 EDT (-0400)
  more interesting functions is isosurface (Message 1 to 7 of 7)
Subject: more interesting functions is isosurface
Date: 11 Sep 2005 00:42:26
Message: <pdbNOSPAM-75E6A0.14422411092005@news.povray.org>
Is it possible to use more interesting user defined float functions
in an isosurface?
When defining the function for an isosurface I would lke to be able
to use #while loops, for example, to compute a series to some specified
precision.
Direct email replies welcome.
Paul Bourke
pdb(NOSPAM)@swin.edu.au
Subject: Re: more interesting functions is isosurface
Date: 11 Sep 2005 00:57:22
Message: <4323b932$1@news.povray.org>
> precision.
Unfortunately, you can't really have loops (although there is a summation
function which can help in some cases) or variables, but some things can be
faked if necessary, especially with recursion.
Here are some handy tricks:
The functional equivalent of precomputing a variable for multiple later uses
is this:
#declare func1 = function(x,y,z, precomputed){...}
#declare func2 = function(x,y,z) {func1(x,y,z, computeSomething(x,y,z))}
An if/else type of thing can be done with select():
select(
    x-3, // "if x is less than 3", or more precisely "if x minus 3 is less
than zero"
    x, // then
    -x // else
And this can be used with recursion, which can be used to replace a while
loop. For instance, Warp once wrote this code to create a mandel fractal
(from "Re: Difference Small objects and Glass Cube" on Tuesday, September
14, 2004 11:28 AM in povray.general):
#declare MandIter =
  function(n, Re, Im, Zr, Zi)
  { select(n>50 | Zr*Zr+Zi*Zi > 4, 0,
           MandIter(n+1, Re, Im, Zr*Zr-Zi*Zi+Re, 2*Zr*Zi+Im), n/50)
#declare Mandel = function(Re, Im) { MandIter(0, Re, Im, Re, Im) }
I think it's best to reply via the newsgroup so the community benefits from
the knowledge passed on.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 11 Sep 2005 02:54:33
Message: <4323d4a9@news.povray.org>
  You say this and then later you give an example of a looping function
(using recursion)... :P
  It's true that user-defined functions don't have a loop structure per se
(like 'for', 'while', etc), but usually you can use recursion to achieve
the same thing (even though the lack of assignable variables makes it a
bit cumbersome sometimes).
Date: 11 Sep 2005 03:25:01
Message: <dg0ls5$3gu$1@chho.imagico.de>
> in an isosurface?
> precision.
In addition to the technique Slime outlined you can of course use #while
etc. in functions to generate functions (whithout actual render time
loops of course).  In some cases this can be an efficient way to
generate complicated functions (if your loop parameters do not depend on
the function parameters).
My waves include file:
http://www.tu-bs.de/%7Ey0013390/pov/water/water_inc.html
gives an example for this.
http://www.tu-bs.de/~y0013390/ (Last updated 24 Jul. 2005)
Date: 11 Sep 2005 08:53:33
Message: <432428D0.4050607@trf.de>
> in an isosurface?
> precision.
In POV-Ray 3.6 (or was it only 3.6.1, I don't remember for sure, I tested
with 3.7 beta), real recursive functions work as an experimental feature.
You still get a possible error reported, but possible errors are non-fatal,
so the parser does continue.  Thus, this should work:
#declare f = function(n) { select(n - 2.01, 1, f(n - 1) + f(n - 2)) }
#declare n = 1;
#while(n < 20)
  #debug str(f(n), 0, 0)
  #debug "\n"
  #declare n = n + 1;
As far as declaring variables inside functions is concerned (as others have
mentioned), sum and prod "declare" an iteration variable, and thus with sum
or prod one can get a _few_ local variables (they are truly local and not
computed more than once) when using them together with a suitable final
value for the iteration.
	Thorsten
Date: 21 Sep 2005 21:05:01
Message: <web.43320316c5f99febde857b690@news.povray.org>
When it comes to tutorials for ISOsurfaces, I highly recommend:
http://www.econym.demon.co.uk/isotut/
It covers the topic in fascinating depth! But I don't recall anything
specific about using controlled loops in an ISOsurface declaration.
Date: 22 Sep 2005 00:53:38
Message: <433238d2@news.povray.org>
  Perhaps that tutorial would benefit from an additional section called
"recursive functions".
