POV-Ray : Newsgroups : povray.general : "Wrapping" an image around a sphere Server Time
28 Feb 2026 17:17:23 EST (-0500)
  "Wrapping" an image around a sphere (Message 1 to 6 of 6)
Subject: "Wrapping" an image around a sphere
Date: 27 Oct 2005 00:05:21
Message: <pan.2005.10.27.04.13.22.298504@contrabandent.com>
I'd like to take a map of a planet and wrap it around a sphere.  I thought
that perhaps the image_map texture was the way to go, but nope - it
doesn't work the way I thought.  (Shoulda read the manual...it works
*exactly* as advertised.)
Any ideas on how to handle such a hack?  The map is in Mercator's
projection.
ICQ#66022322       http://tailkinker.contrabandent.com
    Worker bees can leave
  Even Drones can fly away
The Queen is their slave
Subject: Re: "Wrapping" an image around a sphere
Date: 27 Oct 2005 01:48:31
Message: <pxu5zCAnoGYDFwRx@econym.demon.co.uk>
>projection.
Yes, it's a bit confusing that what POV calls "spherical mapping" is
what cartographers call the "cylindrical projection". If you want areas
near the poles to look right, you have to use some external tool to
convert your map from Mercator to cylindrical projection. I don't know
of any tricks within POV itself that can perform the change of
projection for you.
All the methods of wrapping an image map round a sphere use the same
"cylindrical projection" method:
sphere {0,1
  texture {pigment {image_map{ png "world.png" map_type 1} } }
sphere {0,1
  texture {uv_mapping pigment {image_map{ png "world.png"} } }
sphere {0,1
  texture {pigment {image_map{ png "world.png"} warp {spherical}} }
Mike Williams
Gentleman of Leisure
Date: 27 Oct 2005 04:21:04
Message: <43608df0$1@news.povray.org>
>>projection.
This mean the image x/y-Coordinates are not
interpreted as theta/phi in spherical coordinates?
I always thought it would work this way.
Please correct me if I'm wrong.
Sebastian
Date: 27 Oct 2005 04:24:45
Message: <43608ecd$1@news.povray.org>
> projection.
Huh?!...ah, whew.  The NASA Blue Marble datasets are in cylindrical
projection, I'm safe.
Tim Cook
Version: 3.12
Date: 27 Oct 2005 04:50:33
Message: <Qu6H0DA2RJYDFwHj@econym.demon.co.uk>
>>>projection.
>Sebastian
That how it works in all those types of POV spherical mapping, and in
what cartographers call the "cylindrical projection", but not in the
Mercator projection.
In the Mercator projection, the lines of latitude are spaced further
apart near the poles.
Mike Williams
Date: 27 Oct 2005 05:08:19
Message: <fv671AA2jJYDFwG+@econym.demon.co.uk>
I managed to find an easy tweak that looks pretty good at mapping a
Mercator map onto a sphere. I've no idea if the mathematics are actually
accurate, but I can't see any errors visually.
Simply scale down the sphere by a factor of 2/3, then apply the Mercator
map, then scale it back up again.
#declare S=2/3;
sphere {0,3
  scale <1,S,1>
  texture {pigment {image_map{ png "world.png" map_type 1} }}
  scale <1,1/S,1>
The Mercator image I've been testing with has lines of latitude drawn on
it every 30 degrees, and these test points hit those lines exactly.
sphere {-z*3,0.05  pigment {rgb 1}  rotate -x*60}
sphere {-z*3,0.05  pigment {rgb 1}  rotate -x*30}
sphere {-z*3,0.05  pigment {rgb 1}  rotate x*0}
sphere {-z*3,0.05  pigment {rgb 1}  rotate x*30}
sphere {-z*3,0.05  pigment {rgb 1}  rotate x*60}
Mike Williams
