![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Seems like a colossal waste of CPU. System is Sun Ultra10 workstation,
256M ram, Creator 3D Series III video, Solaris 2.5.1 and yes PovRay is
installed and tested. Since I'm not much of a povray person, I just
play with it, send me your .pov source and I'll render it for you 'cause
the box is doing nothing in particular over the next few days.
Dennis Clarke
ps: I'm doing this because it seems like a waste to have that machine
just spinning its drive and running Conways game of life : )
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I'm curious about a benchmark on it as well.
> Dennis Clarke
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Dennis Clarke <dcl### [at] interlog com> writes:
Just for information, could you post how many candidates you got? I
bet more than 10... Anyway, that is a nice thing. Really. I think I
would send you files, currently I spend too much time trying to get
PVM-POV running on the 600-MHz-each-8-CPU AlphaServer *and* my both
P-II-333-MHz in the same VM to be able to write scene files. And after
that, I think I won't need it any more.
No joking, promise.
Roland.
P.S: No, I'm not offering the same service. These computers are not
mine, but my company's. I even hesitate using them myself (half a
second each time).
bob### [at] casimir rezel enst fr -- Linux, POV-Ray, LaTeX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
And here I thought that spare cpu was rare. Guess not.
In any case, I'm still looking to benchmark it against a 'common' end-user
machine.
> No joking, promise.
> Roland.
> second each time).
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: I have a Sun Ultra10 sitting here doing nothing ...
Date: 18 Aug 1998 04:55:39
Message: <35d9337b.0@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
asdlhf;aht0ap8ht098234h5rn;osadf aoksjdfao
fjfjfjfjfjfjfjjffjjfjfjfjfjfjfjjfjfjjfjfjfhhhhmmmmmmmmmmmmmm...
Sorry, I just got a bit excited... then I calmed down in dispare when I
realised I don't have any files to render at the moment :-(
Lance Birch
http://come.to/the.zone
Remove the smiley to e-mail.
P.S. [SLAP] I needed that!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Check out this benchmark Pov file, It's from ;
http://www.haveland.com/povbench/index.htm
And compare it to a CRAY !
Neil Openshaw
Download 'skyvase.pov.txt' (3 KB)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
$ povray +I./skyvase.pov +v1 -d +ft -x +a0.3000 +r3 -q9 -w640 -h480 -mv2.0 -b1000
+L/usr/local/povray3/include > results.txt
Persistence of Vision(tm) Ray Tracer Version 3.02.SunOS.gcc
This is an official version prepared by the POV-Ray Team(tm). See the
documentation on how to contact the authors or post a message on
CompuServe's GO POVRAY Forum. Also visit http://www.povray.org.
Copyright 1997 POV-Ray Team(tm)
Parsing Options
Input file: ./skyvase.pov (compatible to version 2.0)
Remove bounds........On Split unions........Off
Library paths: /usr/local/povray3/include
Output Options
Image resolution 640 by 480 (rows 1 to 480, columns 1 to 640).
Output file: skyvase.tga, 24 bpp Targa
Graphic display.....Off
Mosaic preview......Off
CPU usage histogram.Off
Continued trace.....Off Allow interruption..Off Pause when done.....Off
Verbose messages.....On
Tracing Options
Quality: 9
Bounding boxes.......On Bounding threshold: 25
Light Buffer.........On Vista Buffer.........On
Antialiasing.........On (Method 1, Threshold 0.300, Depth 3, Jitter 1.00)
Radiosity...........Off
Animation Options
Clock value.... 0.000 (Animation off)
Redirecting Options
All Streams to console..........On
Debug Stream to console.........On
Fatal Stream to console.........On
Render Stream to console........On
Statistics Stream to console....On
Warning Stream to console.......On
Parsing............./skyvase.pov:83: warning: CSG union unnecessarily bounded.
Creating bounding slabs.
Scene contains 4 frame level objects; 3 infinite.
-:--:-- Rendering line 0 of 480Camera is inside a non-hollow object.
Atmosphere, fog, and halo may not work as expected.
0:01:52 Rendering line 480 of 480 supersampled 10 times.
Done Tracing
./skyvase.pov Statistics, Resolution 640 x 480
Pixels: 307840 Samples: 396160 Smpls/Pxl: 1.29
Rays: 1519529 Saved: 9 Max Level: 5/5
Ray->Shape Intersection Tests Succeeded Percentage
Cone/Cylinder 2382548 1281629 53.79
CSG Intersection 3664177 396353 10.82
CSG Union 2563258 738033 28.79
Plane 26388738 14489618 54.91
Quadric 2563258 1571892 61.32
Sphere 2563258 664781 25.94
Bounding Object 2382548 1281629 53.79
Calls to Noise: 1445139 Calls to DNoise: 2816194
Shadow Ray Tests: 3726696 Succeeded: 90401
Reflected Rays: 1123369
Smallest Alloc: 12 bytes Largest: 12828
Peak memory used: 123589 bytes
Time For Trace: 0 hours 1 minutes 52.0 seconds (112 seconds)
Total Time: 0 hours 1 minutes 52.0 seconds (112 seconds)
> Neil Openshaw
> skyvase.pov Type: POV-Ray scene file
(application/x-unknown-content-type-POV-Ray.Scene)
> Encoding: base64
Download 'us-ascii' (8 KB)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
