POV-Ray : Newsgroups : povray.general : unknown "disk" after rotate Server Time
19 Mar 2026 09:44:46 EDT (-0400)
  unknown "disk" after rotate (Message 1 to 3 of 3)
Subject: unknown "disk" after rotate
Date: 17 Apr 2006 15:13:24
Message: <l5q742hrcdkrhltmlth6p086dclgpg57tp@4ax.com>
I am trying to make a bend in a pipe using a torus then cutting off
three quarters with two boxes.  But when I try to rotate the object I
get what looks like a very thin disk.  It only shows up with a rotate
and not a translate.
Where is it coming from and how do I get rid of it?
global_settings {
  assumed_gamma 1.0
  location  <0, 20, -30>
  //direction 1.5*z
  look_at   <0, 0,  0>
light_source {
  <0, 0, 0>
  color rgb <1, 1, 1>
  translate <0, 0, -30>
  shadowless
background { rgb 0.75}
#declare torusMajorRadius = 7;
#declare pipeRadius = 1;
#declare bend =
  difference {
    torus { torusMajorRadius, pipeRadius }
    #declare len = torusMajorRadius + pipeRadius + 1;
    box { <0, -2*pipeRadius, -1*len>, <-len, 2*pipeRadius, len> }
    box { <0, -2*pipeRadius, 0>, <len, 2*pipeRadius, len> }
    translate <0,0,torusMajorRadius>
object {
	bend
	pigment { color Red }
	rotate <0,90,0>
DeLeon Thomas
Subject: Re: unknown "disk" after rotate
Date: 17 Apr 2006 15:35:00
Message: <web.4443edc62053a65a6c4803960@news.povray.org>
Coincident surface problem between your two subtracting boxes (they are
coincident on the x=0 plane)
try:
#declare bend =
  difference {
    box { <-1, -2*pipeRadius, 0>, <len, 2*pipeRadius, len> }
-tgq
Date: 17 Apr 2006 16:26:54
Message: <deu742d3rt85bp1pp88nrmmv7u00knbqqv@4ax.com>
Thank you Trevor!  That fixed everything.
On Mon, 17 Apr 2006 15:34:30 EDT, "Trevor G Quayle"
>try:
>#declare bend =
>  difference {
>-tgq
