POV-Ray : Newsgroups : povray.general : CSDL alpha 2 released Server Time
7 Oct 2024 17:16:08 EDT (-0400)
  CSDL alpha 2 released (Message 1 to 9 of 9)
Subject: CSDL alpha 2 released
Date: 26 Jan 2002 12:02:30
Message: <chrishuff-776795.12040726012002@netplex.aussie.org>
http://homepage.mac.com/chrishuff/csdl/csdl_source.tgz
http://homepage.mac.com/chrishuff/csdl/csdl_distro.tgz
http://homepage.mac.com/chrishuff/csdl/csdl_macosx.tgz
Subject: Re: CSDL alpha 2 released
Date: 28 Jan 2002 12:08:17
Message: <3C558581.88E76346@gmx.de>
I have problems decompressing them, could you check the files?
Date: 28 Jan 2002 12:23:00
Message: <chrishuff-D78D32.12250628012002@netplex.aussie.org>
In article <3C558581.88E76346@gmx.de>,
They worked fine here...did both the source and demo/library files give
you trouble? And what kind of problems?
Date: 28 Jan 2002 12:33:21
Message: <3C558B67.13C32FAC@gmx.de>
Yes, both files.  I get:
$ gzip -d csdl_source02.tgz
gzip: csdl_source02.tgz: invalid compressed data--crc error
gzip: csdl_source02.tgz: invalid compressed data--length error
Date: 28 Jan 2002 17:10:09
Message: <chrishuff-F35D7C.17121828012002@netplex.aussie.org>
In article <3C558B67.13C32FAC@gmx.de>,
Hmm, don't know what's wrong...I'll put up *.zip versions.
Date: 28 Jan 2002 17:46:55
Message: <slrna5bl73.hva.ron.parker@fwi.com>
Your web server doesn't know that a tgz is a binary file, so it's serving
it as text and probably converting newlines.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
Date: 28 Jan 2002 21:46:08
Message: <chrishuff-461FE0.21481628012002@netplex.aussie.org>
In article <slr### [at] fwicom>,
Unfortunately, I have no control of that... :-(
Maybe it would recognize *.tar.gz...or maybe it has something to do with
the way the client requests the file.
Date: 29 Jan 2002 05:53:31
Message: <3C567F01.C175F513@gmx.de>
I got it now using wget on a unix machine (i also used this method with the first
version, just did not remember that).
Compilation with 'USE_OPENGL' did not work, even not after adapting the #include's to
'<Gl/glut.h>' and '<Gl/gl.h>'.  I'm
no expert in C++ or OpenGL so i'm not able to fix this problem but i think it should
compile without errors since Cygwin
supports GLUT.
Here is the output:
g++ -Wall -o csdl_stdlib.o csdl_stdlib.cpp
csdl_stdlib.cpp: In method `class csdl::Base_Data *
csdl::FnInitOpenGLInterface::Run()':
csdl_stdlib.cpp:259: no matching function for call to `csdl::FnNoParams::FnNoParams
(void (&)())'
csdl_stdlib.h:47: candidates are: csdl::FnNoParams::FnNoParams(csdl::FnNoParams *)
csdl_stdlib.h:51:                 csdl::FnNoParams::FnNoParams(void (*)())
csdl_stdlib.h:53:                 csdl::FnNoParams::FnNoParams(const csdl::FnNoParams
csdl_stdlib.cpp:260: no matching function for call to `csdl::FnNoParams::FnNoParams
(void (&)())'
csdl_stdlib.cpp:262: no matching function for call to `csdl::GL3F_Fn::GL3F_Fn (void
(&)(double, double, double))'
csdl_stdlib.h:122: candidates are: csdl::GL3F_Fn::GL3F_Fn(csdl::GL3F_Fn *)
csdl_stdlib.h:127:                 csdl::GL3F_Fn::GL3F_Fn(void (*)(double, double,
double))
csdl_stdlib.h:131:                 csdl::GL3F_Fn::GL3F_Fn(const csdl::GL3F_Fn &)
csdl_stdlib.cpp:263: no matching function for call to `csdl::GL3F_Fn::GL3F_Fn (void
double))
csdl_stdlib.cpp:264: no matching function for call to `csdl::Fn1Scalar<unsigned
int>::Fn1Scalar (void (&)(unsigned int))'
csdl_stdlib.h:63: candidates are: csdl::Fn1Scalar<unsigned
int>::Fn1Scalar(csdl::Fn1Scalar<unsigned int> *)
csdl_stdlib.h:67:                 csdl::Fn1Scalar<unsigned int>::Fn1Scalar(void
(*)(unsigned int))
csdl_stdlib.h:69:                 csdl::Fn1Scalar<unsigned int>::Fn1Scalar(const
csdl::Fn1Scalar<unsigned int> &)
csdl_stdlib.cpp:265: no matching function for call to `csdl::FnNoParams::FnNoParams
(void (&)())'
csdl_stdlib.cpp:266: no matching function for call to `csdl::FnNoParams::FnNoParams
(void (&)())'
csdl_stdlib.cpp:267: no matching function for call to `csdl::FnNoParams::FnNoParams
(void (&)())'
Date: 29 Jan 2002 18:18:25
Message: <chrishuff-3D2C5D.18204329012002@netplex.aussie.org>
In article <3C567F01.C175F513@gmx.de>,
> first version, just did not remember that).
Ah...I wonder if there's some way to force it to transfer properly.
Maybe naming it with a jpg extension or something...or just uploading to
my EarthLink account, which I haven't even used yet.
> #include's to '<Gl/glut.h>' and '<Gl/gl.h>'.  I'm
> should compile without errors since Cygwin supports GLUT.
I think the problem is with the function pointer syntax I used...maybe
passing "&FuncName" will work better than "FuncName". It seems to be
trying to pass a reference to the function, but my C++ books say the
function name is a pointer and use the same syntax I used, and it works
fine in my compiler. I'm still pretty inexperienced with function
pointers though...
