POV-Ray : Newsgroups : povray.general : What to do with the pixel in the middle Server Time
17 Nov 2025 19:30:55 EST (-0500)
  What to do with the pixel in the middle (Message 1 to 10 of 13)
Subject: What to do with the pixel in the middle
Date: 1 Feb 2019 16:34:36
Message: <XnsA9E9E5AA556F3seed7@news.povray.org>
Tinkering with various user defined cameras I often seem to run into the
following; using select in a function you either select bigger smaller or
bigger and equal or smaller:
from a stereo cam:
#local D2_X_Fn = function(u,v){
  select(
    (u<=0),   //u<0????
    -1,
    D1R_X_Fn((u/AspectU*image_width)-0.25,v),
    D1L_X_Fn((u/AspectU*image_width)+0.25,v)
the alternative is select only smaller or bigger resulting in a pixel wide
black line.
So, what to do with the pixel in the middle? Another select with u=0?
ingo
Subject: Re: What to do with the pixel in the middle
Date: 1 Feb 2019 17:05:01
Message: <web.5c54c166738ba468765e06870@news.povray.org>
ingo <ing### [at] tagpovrayorg> wrote:
> from a stereo cam:
>   select(
>     (u<=0),   //u<0????
>     -1,
> black line.
Well, that's a pretty interestingly constructed select() function.
I would have done away with the Boolean operator and the semicolon.
I don't think the one you're using ever results in a <0 value for select() to
operate on, since the boolean operator only returns 0 or 1.
So just to keep myself sane during debugging, I'd write it like:
     select (u,
          D1L_X_Fn ((u/AspectU*image_width)+0.25,v))  // u <  0
          D1R_X_Fn ((u/AspectU*image_width)-0.25,v))  // u >= 0
I guess if you wanted that one-pixel wide strip at the center to use the other
function, then you'd use the 4-argument version and repeat the first function
for the u = 0 case.
Hopefully at some point you can share some of your understanding of the
user-defined camera with a few simple explanatory examples / tutorials.
Date: 1 Feb 2019 18:15:37
Message: <XnsA9EA2A6B5B0Dseed7@news.povray.org>
> the other function, then you'd use the 4-argument version and repeat
> the first function for the u = 0 case.
Bill,
on an almost "aside way" you explain me that things can be done simpler
and then ask:
> the user-defined camera with a few simple explanatory examples /
> tutorials.
in the land of 'nikked' eagles one feather ain't king ;)
but seriously, I almost exclusivly use the 4 term select as:
select(query, ignore(=-1), true, false)
Regarding the pixel in the middle, where does it belong ??? In case of a
stereo cam, the left or right side of the image, there is no in between?
User defined cameras are great, just starting to explore them, but ...
they are indeed rather under documented. It's hard to understand what
exactly happens, but once I get it I'm willing to do a write up (to be
corrected by the ones that realy understand). An other thing is that they
seem to be "verbose". When I try to reimplement an existing 10 line of c++
code cam it seems I need at least 5 times more space. It requires a lot of
trials and mostley errors as I have a hard time wrapping my brain around
some things and my brain isn't very structured, more intuitive.
Ray tracing is about rays, objects an cameras and I realy think POV-Ray
deserves a whealthy choise of ready made cameras. Paul Bourke has defined
a very nice set of stereo cameras a decade ago that I.M.H.O would be very
welcome in an official distribution. Le Forgeron, as I discovered today,
has made a set of _/incredible and bewildering/_ set of 'planet mapping'
camera's. The https://www.cartographersguild.com would love them (/him for
that), they do not seem to have discovered them yet. Let's not forget
Fabrizio's (Clodi) OSD camera.
ingo
Date: 1 Feb 2019 18:33:31
Message: <XnsA9EA5AF9A331seed7@news.povray.org>
in news:XnsA9EA2A6B5B0Dseed7@news.povray.org ingo wrote:
> they seem to be "verbose"
A dense stereo cam file for example. Sanity check before serious use,
ingo
#version 3.8;
global_settings{ assumed_gamma 1.0 }
#include "math.inc"
#include "transforms.inc"
//#include "udCameras.inc"
#macro udcLookAtTransform(
    D0_X_Fn, D0_Y_Fn, D0_Z_Fn,
    pLocation, pLookAt, Angle,
    optional Roll, optional vDirection,
    optional vRight, optional vUp
  Transforms the direction function of a user defined camera to look into
the
  pLookAt direction from the camera location.
  Code base by: Tor Olav Kristensen, http://subcube.com
  This macro is intended to be used in user defined cameras.
  For example use, see udcPerspective().
  D0_X_Fn, D0_Y_Fn, D0_Z_Fn (function): the original camera direction
functions.
  pLocation  (vec) : the location of the camera
  pLookAt    (vec) : the point to look at
  Angle    (float) : horizontal field of view o view angle
  Roll     (float) : optional, defaults to 0.
                     Roll, a.k.a. banking, rotates the camera around the
view
                     direction vector.
  vDirection (vec) : optional, defaults to +z.
  vRigth     (vec) : optional, defaults to
<image_width/image_height,0,0>.
  vUp        (vec) : optional, defaults to +y.
  #ifndef(local.Roll)
    #local Roll = 0;
  #ifndef(local.vDirection)
    #local vDirection = +1*z;
  #ifndef(local.vRight)
      #local vRight = +image_width/image_height*x;
  #ifndef(local.vUp)
    #local vUp = +1*y;
  #local vLookAt = pLookAt - pLocation;
  #local LookAtTransform = transform{
    Reorient_Trans(z, vLookAt)
    Axis_Rotate_Trans(vLookAt, Roll)
  #local vDirection_1 = vtransform(vDirection, LookAtTransform);
  #local vRight_1 = vtransform(vRight, LookAtTransform);
  #local vUp_1 = vtransform(vUp, LookAtTransform);
  #local <X1_X, X1_Y, X1_Z> = vtransform(x, LookAtTransform);
  #local <Y1_X, Y1_Y, Y1_Z> = vtransform(y, LookAtTransform);
  #local <Z1_X, Z1_Y, Z1_Z> = vtransform(z, LookAtTransform);
  #local D1_X_Fn = function(u,v){
    0
    + X1_X*D0_X_Fn(u,v)
    + Y1_X*D0_Y_Fn(u,v)
    + Z1_X*D0_Z_Fn(u,v)
  #local D1_Y_Fn = function(u,v){
    0
    + X1_Y*D0_X_Fn(u, v)
    + Y1_Y*D0_Y_Fn(u, v)
    + Z1_Y*D0_Z_Fn(u, v)
  #local D1_Z_Fn = function(u,v){
    0
    + X1_Z*D0_X_Fn(u, v)
    + Y1_Z*D0_Y_Fn(u, v)
    + Z1_Z*D0_Z_Fn(u, v)
  (D1_X_Fn, D1_Y_Fn, D1_Z_Fn)
#macro udcStereo(pLocation,pLookAt,Angle,FocalDist)
  //http://paulbourke.net/stereographics/stereorender/
  #local EyeSep = FocalDist/30;
  #local Delta  = (image_width*EyeSep)/(2*FocalDist*tand(Angle/2));
  #local Angle1 = 2*atand((image_width+Delta)*tand(Angle/2)/image_width);
  #local AspectU = image_width+Delta+Delta;
  #local AspectV = image_height;
  #local vMovement  = EyeSep/2*vnormalize(vcross(pLookAt-pLocation,
<0,1,0>));
  #local pLocationL = pLocation+vMovement;
  #local pLocationR = pLocation-vMovement;
  #local <LocationXL, LocationYL, LocationZL> = pLocationL;
  #local <LocationXR, LocationYR, LocationZR> = pLocationR;
  #local LocationX = function(u){select((u<=0),-1, LocationXR,
LocationXL)};
  #local LocationY = function(u){select((u<=0),-1, LocationYR,
LocationYL)};
  #local LocationZ = function(u){select((u<=0),-1, LocationZR,
LocationZL)};
  #local D0_X_Fn = function(u,v){u*AspectU};
  #local D0_Y_Fn = function(u,v){v*AspectV};
  #local D0_Z_Fn = function(u,v){AspectU/2/tand(Angle/2)};
  #local pLookAtL = pLookAt+vMovement;
  #local pLookAtR = pLookAt-vMovement;
  #local(D1L_X_Fn, D1L_Y_Fn, D1L_Z_Fn) = udcLookAtTransform(
    D0_X_Fn, D0_Y_Fn, D0_Z_Fn, pLocationL, pLookAtL, Angle1,,,,
  #local(D1R_X_Fn, D1R_Y_Fn, D1R_Z_Fn) = udcLookAtTransform(
    D0_X_Fn, D0_Y_Fn, D0_Z_Fn, pLocationR, pLookAtR, Angle1,,,,
  #local D2_X_Fn = function(u,v){select(
    (u<=0),
    -1,
  #local D2_Y_Fn = function(u,v){select((u<=0),-1, D1R_Y_Fn(u-0.25,v),
D1L_Y_Fn(u+0.25,v))};
  #local D2_Z_Fn = function(u,v){select((u<=0),-1, D1R_Z_Fn(u-0.25,v),
D1L_Z_Fn(u+0.25,v))};
    user_defined
    location {
      function {LocationX(u)}
      function {LocationY(u)}
      function {LocationZ(u)}
    direction {
      function {D2_X_Fn(u,v)}
      function {D2_Y_Fn(u,v)}
      function {D2_Z_Fn(u,v)}
#declare ZeroParallax = 3;
udcStereo(<0,0,-ZeroParallax>,<0,0,0>,55,ZeroParallax)
light_source{< 1000,1000,-1000>, rgb 1}
light_source{<-1000,1000,-1000>, rgb .3}
difference{
  box{-0.5,0.5 pigment{rgb 1}}
  box{-0.5,0.5 scale <0.97,0.97,1.20>}
  box{-0.5,0.5 scale <0.97,1.20,0.97>}
  box{-0.5,0.5 scale <1.20,0.97,0.97>}
sphere{<0,-0.2,-1>,0.035 pigment{rgb z}}
sphere{<0,0.2,10>,0.03 pigment{rgb 1}}
plane{y,-1.5 pigment{checker}}
plane{z,20 pigment{function{abs(y)} scale 12 translate<0,-1.5,0>}}
sphere{<0, 0.0, 0>,0.03 pigment{rgb y}}
Date: 1 Feb 2019 20:40:01
Message: <web.5c54f447738ba468765e06870@news.povray.org>
> Bill,
Well, it's not "simpler" - it's just more straightforward for the easily
confused such as me.   :P
Well, whatever works for you, if you use it consistently without problems - go
for it.
Nope.  I suppose you could do the calculations and find out where to shift the
camera so that it's "1 pixel" over one way or the other, and then adjust for
that...
Can you check and see if abs (u) > epsilon so that you can filter out a lot of
"0" results...?
Sure, I think the idea is to just post some reasonably well commented code, that
we can look at when we want to implement a similar camera structure, and if
necessary, supplement with some renders, drawings, etc.
I seem to be able to teach myself what I need to know faster when I try to
explain the problem I'm having, or when I try to condense it down into a macro
or a formula.
I think there's a LOT of Bourke's work that ought to be readily available and
used a lot more, and even implemented under the hood in C++ so that it's not
stuck in super-slow SDL.
> camera's.
Jerome is a really intelligent, inventive, and hard-working guy, and I wish I
had more time to sit down and play with all of the goodies he has coded up over
the years.
Yet another forum to advertise the wonders of POV-Ray in   :)
> Let's not forget
I have not (yet) heard of that.
Aha -
http://news.povray.org/povray.general/thread/%3Cweb.56d38071f91c97bb4e8811590%40news.povray.org%3E/?mtop=406634
(Clodo)
Date: 1 Feb 2019 21:21:14
Message: <5c54fe9a$1@news.povray.org>
Am 02.02.2019 um 00:15 schrieb ingo:
That is a fundamental problem - but if you think about it, it's not
specific to user-defined stereo cameras, but to stereo images with an
odd number of pixels.
An even-numbered pixel image does not have any pixel at the center - it
has a _pixel border_ at the center.
Date: 2 Feb 2019 03:08:57
Message: <XnsA9EA5D1365E05seed7@news.povray.org>
in news:5c54fe9a$1@news.povray.org clipka wrote:
> think about it
The back pixel in the middle makes sense,
thanks,
ingo
Date: 2 Feb 2019 03:15:34
Message: <XnsA9EA5E327FBDEseed7@news.povray.org>
> try to explain the problem I'm having, or when I try to condense it
> down into a macro or a formula.
"literate programming" (http://www.literateprogramming.com/)
On most stuff I do I just start with writing down the story, then add
snippets of code and slowly condense the story into code.
ingo
Date: 2 Feb 2019 13:35:00
Message: <web.5c55e1be738ba468c143b2b0@news.povray.org>
> > think about it
To achieve this you can make the camera look another way when u equals zero,
e.g. like this:
direction {
    function {
        select(
            u,
            D1L_X_Fn(u*image_width/AspectU + 0.25, v),
            0,
            D1R_X_Fn(u*image_width/AspectU - 0.25, v)
    function {
        select(
            u,
            D1L_Y_Fn(u + 0.25, v),
            1,
            D1R_Y_Fn(u - 0.25, v)
    function {
        select(
            u,
            D1L_Z_Fn(u + 0.25, v),
            0,
            D1R_Z_Fn(u - 0.25, v)
- and then place something small with a black pigment, no_shadow and
no_reflection close to the camera in that direction (e.g. right above the
camera).
Tor Olav
http://subcube.com
Date: 2 Feb 2019 14:45:00
Message: <web.5c55f204738ba468c143b2b0@news.povray.org>
> the
> functions.
> view
>                      direction vector.
>   #ifndef(local.Roll)
>     #local Roll = 0;
>   #end
>   #end
>   #end
>   #ifndef(local.vUp)
>     #local vUp = +1*y;
>   #end
>     0
>     + X1_X*D0_X_Fn(u,v)
>     + Y1_X*D0_Y_Fn(u,v)
>     + Z1_X*D0_Z_Fn(u,v)
>     0
>     0
> #end
> <0,1,0>));
> LocationXL)};
> LocationYL)};
> LocationZL)};
>     (u<=0),
>     -1,
>   camera {
>     user_defined
>     location {
>     direction {
> #end
Note that vDirection_1, vRight_1 and vUp_1 are calculated in your
udcLookAtTransform macro, but not used for anything. So I suggest that you
remove them, and also vDirection, vRight and vUp, as you you will not be able to
change the default direction vectors for the user defined camera.
Further, I assume that you are implementing "Off-axis" stereo camera pairs. If
so then the corresponding direction vectors for both cameras will all be
parallel. (But their position and field of view will be different.) Therefore
you do not need to create two different direction function sets for them. You
can create a common set based on the initial pLocation and pLookAt positions.
Tor Olav
http://subcube.com
