POV-Ray : Newsgroups : povray.general : change root dir of include? Server Time
1 Mar 2026 09:06:29 EST (-0500)
  change root dir of include? (Message 1 to 2 of 2)
Subject: change root dir of include?
Date: 8 Jan 2005 12:19:59
Message: <Xns95D8BA9A97605raf256com@203.29.75.35>
I have scene in example
  scene.pov
in some directory like dir/.  Scene includes some local files, so
include "data.inc" inside dir/scene.pov refers to dir/data.inc
If I open scene.pov and render it - it works.
If I create a file render.pov and from it include dir/scene.pov - it doesnt
work, since #include in dir/scene.pov refers to data.inc not dir/data.inc
I can fix it by adding  #declare root="dir/" inside render.pov, and then
change all #includes in files in dir/* to
#include concat( root , "something" );
But if there are several files inside dir/ and there have several includes,
in example - files exported using Polyray, it become annoying.
Is there some future to include file where file-name is relative to current
file, not to main .pov file?  Or - how about adding some SetRoot() option,
it would be used like:
#declare oldRoot = getfileroot();
setfileroot("car10")
#include "main.pov" // includes car10/main.pov and other includes there are
  // relative  to car10/ so they work o.k.
setfileroot(oldRoot); // restore root
http://www.raf256.com/3d/
Computer Graphics
Subject: Re: change root dir of include?
Date: 8 Jan 2005 14:19:21
Message: <41e03239@news.povray.org>
I'm guessing you are not overlooking the obvious solution, Library_Path, as
used in the povray.ini file and instead want a way to do this from within a
scene file.
Only thing besides, I can think of, might be a Pre_Scene_Command to change
the working directory (of Windows). Unfortunately, while trying a test of
this before replying to you I couldn't use that idea, POV-Ray crashes. There
had been problems with that feature during beta testing which I thought had
been corrected but using it like in the documentation I'm not able to use
it. Tried with/without quotes.
Bob H.
