POV-Ray : Newsgroups : povray.general : Realy uniform points on sphere Server Time
13 Nov 2025 07:19:29 EST (-0500)
  Realy uniform points on sphere (Message 1 to 4 of 4)
Subject: Realy uniform points on sphere
Date: 19 Nov 2004 09:42:57
Message: <Xns95A6A03392860raf256com@203.29.75.35>
is there a macro to place points realy uniformly (in almost distances from
each point to it's neighbours)?
VRand_On_Sphere() places each point correclty, but it doesnt care about
other points, so when used in loop - the resulting _group_ of points isnt
so uniformly placed.
This problem is simmilar to finding good points/vectors to be used in
radiosity directions AFAIK (but it's about full sphere, not half of it).
http://www.raf256.com/3d/
Computer Graphics
Subject: Re: Realy uniform points on sphere
Date: 19 Nov 2004 09:50:25
Message: <419e0831$1@news.povray.org>
Rafal 'Raf256' Maj wrote:
> Hi,
As I understand it, there are only a few truly uniform distributions. If
you're not overly particular about the exact number of points, you can
just start with one of the platonic solids (I think the best looking
distributions come from a cube, icosahedron might give the closest to
even) and keep diving the faces to get a relatively even distribution.
If you're just talking about just a few points, Tim Nikias has IIRC an
electrostatic repulsion macro on his website.
  -Shay
Date: 19 Nov 2004 10:23:31
Message: <Xns95A6A713AFB7raf256com@203.29.75.35>
sah### [at] simcopartscom news:419e0831$1@news.povray.org
> If you're not overly particular about the exact number of points, you
> can just start with one of the platonic solids (I think the best
> looking distributions come from a cube, icosahedron might give the
> closest to even) and keep diving the faces to get a relatively even
> distribution.
Some related links:
http://news.povray.org/povray.binaries.images/thread/%3CXns93266109FE342fiz
ban### [at] 204213191226%3E/?ttop=189070&toff=1000
http://news.povray.org/povray.advanced-
users/thread/%3C4### [at] triplexde%3E/?ttop=202454&toff=50
http://www.math.niu.edu/~rusin/known-math/index/spheres.html
And finaly:
http://www.nolights.de/download.html#ESR
Computer Graphics
Date: 22 Nov 2004 04:22:36
Message: <41a1afdc$1@news.povray.org>
"Rafal 'Raf256' Maj" <spa### [at] raf256com> schrieb im Newsbeitrag
news:Xns95A6A03392860raf256com@203.29.75.35...
> Hi,
Hi
As the others said, there are only approximations possible for arbitrary
large numbers of points.
Sorry if i'm annoying anyone with repeatedly stating the usefulness
of the golden-ratio-approach ; ) ... but i use it with good results.
It's not perfect and probably optimizing the positions with an
electrostatic-repulsion approach can give more optimal results but
i think this method is by far the fastest and for many points it gives
nice results.
Greetings,
Thies
Here's my approach:
#version 3.5;
global_settings {
  assumed_gamma 1.0
  max_trace_level 5
  location  <1.3, 3.5, -1.0>
  direction 1.5*z
  look_at   <0.0, 0.0,  0.0>
sky_sphere {
    gradient y
    color_map {
      [0.0 rgb <0.6,0.7,1.0>]
      [0.7 rgb <0.0,0.1,0.8>]
light_source {
  <-20, 30, -60>
  color rgb <0.9, 0.7, 0.3>
light_source {
  <70, 40, 80>
  color rgb <0.1, 0.3, 0.9>
#declare N  = 5000; // Number of Spheres
#declare M  = N;
#declare sr = 0.8 * 2/sqrt(N);  // sphereradius
#declare phi= 0;
#declare gsa= 360*((sqrt(5)-1)/2);  // golden section angle
#declare py = -1;
#while(M>0)
  sphere {
    py*y, sr
    translate sqrt(1-py*py)*x
    rotate phi*y
      pigment{color rgb 1}
      finish{ambient 0 diffuse 0.5 reflection{0.3, 0.7}}
  #declare py=-1+2*(M-1)/(N-1);
  #declare phi=phi+gsa;
  #declare M=M-1;
