POV-Ray : Newsgroups : povray.general : Too many nested refracting objects. Server Time
1 Feb 2026 07:32:43 EST (-0500)
  Too many nested refracting objects. (Message 1 to 3 of 3)
Subject: Too many nested refracting objects.
Date: 19 Jul 2004 16:47:23
Message: <Xns952BE7467EF9Fraf256com@203.29.75.35>
I have problem with "Too many nested refracting objects."
after changine an L-system plant (my underwater plant CSS-3 entry) into an
media instead off plain pigment{...} solid object.
  Remove bounds........On
  Split unions.........Off
  (btw - what exacly does this option do, maybe it can help? or increase
speed of rendering in cost off bigger memory usage for more bounding
boxes?)
  Bounding boxes.......On   Bounding threshold: 3
  Light Buffer.........On
  Vista Buffer.........On   Draw Vista Buffer....Off
Scene Statistics
  Finite objects:       217742
  Infinite objects:          1
  Light sources:             1
  Total:                217744
Rendering Error: Too many nested refracting objects.  (<<<<<<<<<<<<)
  Total Time:    0 hours  1 minutes 39 seconds (99 seconds)
How can I get rid of this problem?
Main object, after unrolling recurency is something like
union {
  union {
    union { cylinder{} cylinder{} cylinder{} }
_Each_  cylinder have own texture settings (different colors)
like :
  pigment { rgbf 1 }
  interior { media { emission <..,..,..> } }
http://www.raf256.com/3d/
Computer Graphics
Subject: Re: Too many nested refracting objects.
Date: 19 Jul 2004 23:28:47
Message: <40fc916f$1@news.povray.org>
Rafal 'Raf256' Maj nous apporta ses lumieres ainsi en ce 19/07/2004
16:47... :
It remove some redundant manual boundings, mainly when the auto-bounding
hapens to be tighter. It may increase render time.
>boxes?)
It break up unions to get beter bounding. This leads to faster render
time as it can greatly reduce the number of intersection tests. If you
have 2 or 3 long and narrow perpendicular cylinders in an union, if OFF,
you have to test in the bounds of the whole, almost empty large bounding
box instead of just in 3 narow boxes.
>Scene Statistics
>  Infinite objects:          1
>  Light sources:             1
>  Total:                217744
>union {
>  union {
>like :
>  pigment { rgbf 1 }
Are those cylinders coaxials? Like all along the X axis between about
the same coodinates. Do they have an ior value, or do you have an ior
set as a default? Are there many intersecting ones?
Just a gues: try increasing the value for adc_bailout in the
global_settings block.
Date: 20 Jul 2004 14:03:32
Message: <kurtzlepirate-77B082.20033220072004@news.povray.org>
In article <Xns952BE7467EF9Fraf256com@203.29.75.35>,
 "Rafal 'Raf256' Maj" <spa### [at] raf256com> wrote:
> union {
>   union {
  why union { union { union ...
  why not :
  union {
    cylinder {}
    cylinder {}
    cylinder {}
    cylinder {}
    cylinder {}
