POV-Ray : Newsgroups : povray.general : Groves in sphere Server Time
1 Feb 2026 07:42:30 EST (-0500)
  Groves in sphere (Message 1 to 2 of 2)
Subject: Groves in sphere
Date: 17 Jul 2004 06:45:35
Message: <Xns952981CF4EA51noemailheresorry@203.29.75.35>
I want to growe few rows on a sphere surface - how can I do it?
One of ideas would be to difference a sphere with a part of torus with same radius
and center.
difference {
  sphere { 0 R }
  intersection {
    torus { R 0.05 }
    box { ... } // only part of torus
    rotate ...
  [... more intersections ...]
I would rather like to have my bups/groves in a .bmp file... so I need something
like height_field, but wrapped into a sphere (I will need only a small part of
sphere about 1/10th of its surface so distorsions aroud "edges" of sphere/texture
- is not a problem)
Other soulution would be maybe to use
sphere { 0 R  normal { bump_map { bmp .....
but I need very realistic results, normals are not enought.
Hmm maybe some isosurface (or parametric) - but this soulution is very slow...
Or maybe some macro to generate a curved heightfield from an pattern / image? (or
just to generate an HF-mesh, I will try to adjust it)  or any other sugestions..
Subject: Re: Groves in sphere
Date: 17 Jul 2004 07:07:23
Message: <iGokfAAleQ+AFwPR@econym.demon.co.uk>
Wasn't it no.### [at] heresorry who wrote:
>Hi,
>radius
>and center.
>difference {
>  sphere { 0 R }
>  intersection {
>    torus { R 0.05 }
>    rotate ...
>sphere/texture
>- is not a problem)
Simple isosurfaces like this are not all that slow. Try this for grooves
that follow lines of latitude. It only takes about 7 times longer than
rendering a plain sphere{0,1}.
#include "functions.inc"
#declare Frequency=60;
#declare Depth=0.02;
isosurface {
  function {f_sphere(x,y,z,1) + sin(Frequency*f_ph(x,y,z))*Depth}
  max_gradient 1.8
  contained_by {sphere {0,1}}
  pigment {rgb 1}
If you don't want sharp edges on the sides of the grooves use
  contained_by {sphere {0,1+Depth}}
For lines of longitude use
  sin(Frequency*f_th(x,y,z))
For lines of latitude that get closer near the equator use
  sin(Frequency*y)
Mike Williams
Gentleman of Leisure
