POV-Ray : Newsgroups : povray.general : Re: Big whopping sparks Server Time
18 Feb 2025 17:00:10 EST (-0500)
  Re: Big whopping sparks (Message 1 to 10 of 19)
Subject: Re: Big whopping sparks
Date: 15 May 2004 23:33:09
Message: <Xns94EB384D96A5Braf256com@203.29.75.35>
dva### [at] cedarnet news:40a6e00d@news.povray.org
> What sort of options are available for making big whopping sparks that
> light up the scene?
FOr questions please use povray.general (or .newusers).
As for sparks, You can use
1) small bat very bright emission media
2) small spheres/etc with high ambient finish
3) real light sources
options 1) and 2) need radiosity and therefore are usualy slow, on the
other hand using 3) is slow when YOu have too meany sparks.
Btw funny I was qoing to write a small FAQ/tutorial about it I hope You
will find it usefull :)
http://www.raf256.com/3d/
Computer Graphics
Date: 16 May 2004 00:01:21
Message: <40a6e791$1@news.povray.org>
"Rafal 'Raf256' Maj" <spa### [at] raf256com> wrote in message
news:Xns94EB384D96A5Braf256com@203.29.75.35...
> > light up the scene?
ALrighty then.. :)
Well, 38 smallish sparks, and one big whopping one.
Cool.
Date: 16 May 2004 08:43:15
Message: <40a761e3$1@news.povray.org>
Dave VanHorn nous apporta ses lumieres ainsi en ce 2004/05/16 00:02... :
>>>light up the scene?
>ALrighty then.. :)
>>1) small but very bright emission media
>Cool.
With that kind of count, I'd go for solutions 1 and/or 2, could give you
better results in less time.
Date: 16 May 2004 09:42:38
Message: <40a76fce$1@news.povray.org>
> Alain
Ok, #1 sounds good, but how do you actually generate something that looks
spark-like?
I found an include file for Megapov, but I'd rather stick with Pov-ray.
Date: 16 May 2004 10:24:11
Message: <40a7798b$1@news.povray.org>
Dave VanHorn nous apporta ses lumieres ainsi en ce 2004/05/16 09:43... :
>>Alain
>spark-like?
A merge of some narrow cylinders and sharp cones filed with media could
be a starter. You may need some spheres to fill some gaps.
You can adjust the magapov include to use it with POV-Ray, it take some
work and testing.
Date: 16 May 2004 12:28:09
Message: <40A79696.73CCE919@hotmail.com>
> > light up the scene?
You can use small ambient=1 no_shadow objects to model the sparks, but
a light source for each spark may not always be needed; a light source
in the middle of a group of sparks may be enough to look realistic.
If the sparks are in motion, you need to model them as portions of
a tube, or use some kind of motion blur.
John
Date: 17 May 2004 12:30:53
Message: <40a8e8bd$1@news.povray.org>
In news:40a76fce$1@news.povray.org,
Dave VanHorn <dva### [at] cedarnet> typed:
> looks spark-like?
> Pov-ray.
I did a spark as a test once. I think it looks rather nice and it
renders quite fast too.
Furtunatly I still have the code around.
/ Daniel Nilsson
Cut here...
#include "metals.inc"
  location <5, 4, -10>
  look_at <0, -4, 0>
light_source { <0, 0, 0> rgb <0.1, 0.4, 1.0>
  area_light x*5.9, z*0.3, 5, 3
  adaptive 1
  fade_distance 4
  fade_power 2
sphere { <-4, 0, 0>, 1 texture { T_Chrome_2E } }
sphere { <4, 0, 0>, 1 texture { T_Chrome_2E } }
cylinder { <-4, 0, 0>, <-4, -10, 0>, 0.1 texture { T_Chrome_2E } }
cylinder { <4, 0, 0>, <4, -10, 0>, 0.1 texture { T_Chrome_2E } }
plane { y, -10 pigment { White } }
cylinder { <-4, 0, 0>, <4, 0, 0>, 1.1
  hollow
  pigment { Clear }
  interior {
    media {
      method 3            // 3
      aa_level 3          // 4
      aa_threshold 0.05   // 0.1
      samples 16, 100     // Min 1, Max 1
      intervals 1         // 10
      ratio 0.9           // 0.9
      confidence 0.9      // 0.9
      variance 1/128      // 1/128
      jitter 0
      emission 1
      density {
        cylindrical
        rotate z*90
        color_map {
          [ 0.00 Black ]
          [ 0.40 rgb <0.1, 0.4, 1.0>*0.1 ]
          [ 0.80 rgb <0.1, 0.4, 1.0>*0.5 ]
          [ 0.90 rgb <0.1, 0.4, 1.0>*1.0 ]
          [ 1.00 rgb <0.1, 0.4, 1.0>*10 ]
        warp {
          turbulence 0.5     // amount of turbulence
          octaves 4          // optional turbulence modifiers
          lambda 2
          omega 0.5
Date: 17 May 2004 13:46:01
Message: <40a8fa59@news.povray.org>
Looks good, now I have to see if I can get it into my scene.
Two banks of nine, plus one whopping big one.
BTW: Does this sort of spark, act as a light source?
Date: 17 May 2004 14:47:44
Message: <40a908d0@news.povray.org>
In news:40a8fa59@news.povray.org,
It's the cylinder with its media interior that is the spark (but you've
allready figured that out, I guess), change its length and/or scale it
to make it fit your scene then translate/rotate it in place.
The spark in my code does not light up the scene by it self unless you
use radiosity (I have not tested that with this scene). I included one
area light to approximate the light from the spark.
/ Daniel Nilsson
Date: 17 May 2004 19:12:40
Message: <40a946e8$1@news.povray.org>
I'm having limited success.  I've got some control over it, but not having
any luck at scaling it out to the big spark, 22 inches long (22 pov units,
or 220 pov units, or... )  Everything I do is scaled in inches, mm, or some
other real unit, so that measured parts actually fit in the scene.
I have radiosity turned on, but how do I make the sparks act as light
sources?
