![](/i/fill.gif) |
I have a scene with two planes; I want the first to appear when the clock is
below .7 and the second when it is above .7:
#if (clock <.7)
plane 1 {...}
#else
plane 2 {...}
But what if I wanted plane 1 when the clock was between, say 0 and .5, then
plane 2 when it was between .5 and .7, then plane 1 to return again between
.7 to .9, then plane 2 between .9 and 1?
How can I do a multisegment if/else or something comparable?
Thanks,
Dennis
dhm### [at] comcast net
http://www.dennismiller.neu.edu
![](/i/fill.gif) |
![](/i/fill.gif) |
Dennis Miller nous apporta ses lumieres ainsi en ce 2004/04/15 17:34... :
>#if (clock <.7)
>plane 1 {...}
>#else
>plane 2 {...}
>#end
>Thanks,
>Dennis
you can nest #if like this:
#if (condition1)
<code>
#else
#if(condition2)
<code>
#else
You can use the #switch, #case, #range and #break directives
Look at item 6.2.6.3
![](/i/fill.gif) |
