POV-Ray : Newsgroups : povray.general : explicit color mapping f(u,v)->color Server Time
18 Feb 2025 18:08:47 EST (-0500)
  explicit color mapping f(u,v)->color (Message 1 to 7 of 7)
Subject: explicit color mapping f(u,v)->color
Date: 4 Oct 2003 14:31:37
Message: <3f7f1209$1@news.povray.org>
This may be obvious, and I've simply overlooked it, but I can't seem to
figure out a way to explicitly say what color I want at a specific point
on a surface.  Basically what I want is a way to draw the u and v
coordinate lines ...u = -2, u = -1, u = 0, u = 1, u = 2 ...,...v = -2, v
= -1, v = 0, v = 1, v = 2 ..., etc.
This *seems* like it should be easy.  Suggestions?
STH
Subject: Re: explicit color mapping f(u,v)->color
Date: 4 Oct 2003 20:25:50
Message: <xQeA6JA6P2f$Ew7E@econym.demon.co.uk>
If the object is one of those which supports uv_mapping, then you can
use a uu_mapped pigment function something like this:
#declare Spacing = 20;
sphere {0,1
  uv_mapping
    function {min(abs(sin(u*pi*Spacing)),
              abs(sin(v*2*Spacing)))}
    color_map { [0.0 rgb 0]
                [0.05 rgb 0]
                [0.05 rgb 1]
                [1 rgb 1]
Mike Williams
Gentleman of Leisure
Date: 5 Oct 2003 20:14:51
Message: <3f80b3fb@news.povray.org>
> sphere {0,1
>   uv_mapping
>   pigment {
>                 [0.05 rgb 0]
>                 [0.05 rgb 1]
>                 [1 rgb 1]
Thanks.
It looks as though the answere is 'yes, and no'.  I wanted to do this
with  a parameterized object or an isosurface.  *6.7.7.1 Supported
Objects* of the docs is telling me I can't do it.  This *seems* somewhat
strange since I am already defining the parameterized object in terms of
UV parameters.  What I've done is to create a composite of areas
excluding the coordinate line areas, and then create a union of all
patches and coordinate lines.
This does not render very quickly, but it produces the basic desired
result.  Now the next trick will be to draw an arbitrary curve on said
surface.
<scratches head>
STH
Date: 5 Oct 2003 21:12:50
Message: <DLFTNAAoCMg$EwEV@econym.demon.co.uk>
>> sphere {0,1
>>   uv_mapping
>>   pigment {
>>                 [0.05 rgb 0]
>>                 [0.05 rgb 1]
>>                 [1 rgb 1]
>Thanks.
>surface.
Have you considered using Ingo Janssen's "param.inc" system? This
generates a mesh2 object which closely approximates a parametric
isosurface. This has the advantages of being very much faster to render,
and supporting uv_mapping.
Ingo's website: <http://members.home.nl/seedseven/>
My tutorial page: <http://www.econym.demon.co.uk/isotut/param.htm>
Mike Williams
Date: 6 Oct 2003 02:52:28
Message: <9q32ovo8ghf1fldrqs0fmslvfe9ltv4ipv@4ax.com>
On Sun, 05 Oct 2003 20:14:47 -0400, fjolsvit <fjo### [at] netscapenet> wrote:
> UV parameters.
I noticed this very early after 3.5 relase and made a patch
http://abx.art.pl/pov/patches/uvparam.php which was included in MegaPOV 1.0
http://megapov.inetart.net/manual/objects.html#uv_param . AFAIK this 'kind of
bug' will be fixed in 3.5.1.
ABX
Date: 6 Oct 2003 10:04:11
Message: <Xns942AA33B14E90torolavkhotmailcom@204.213.191.226>
> surface.
See my code below for a way to draw simple functions on an
uv-mapped surface.
It shouldn't be very difficult to add a coordinate grid to
the surface pigment too.
Tor Olav
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
#declare LW = 0.01; // Line Width
#declare SelFn =
  function(A) {
    select(A, select(A + LW/2, 0, 1), select(A - LW/2, 1, 0))
#declare OneLineFn = function(u, v) { SelFn(v - u) }
#declare DrawFn =
  function(u) { 0.5 + 0.25*sin(4*pi*u) + 0.25*cos(5*pi*u) }
//#declare DrawFn = function(u) { 0.5 + 0.5*sin(2*pi*u) }
bicubic_patch {
  type 0
  flatness 0.01
  u_steps 4
  v_steps 4
  <0, 0, 0>, <1, 0, 0>, <2, 0, 0>, <3, 0, 0>,
  <0, 1, 0>, <1, 1, 0>, <2, 1, 0>, <3, 1, 0>,
  <0, 2, 0>, <1, 2, 0>, <2, 2, 0>, <3, 2, 0>,
  <0, 3, 0>, <1, 3, 0>, <2, 3, 0>, <3, 3, 0>
  uv_mapping
      function { OneLineFn(DrawFn(u), v) }
      color_map {
        [ 0 color rgb <1, 1, 1> ]
        [ 1 color rgb <1, 0, 0> ]
  location <1.5, 1.5, -4>
  look_at <1.5, 1.5, 0>
light_source {
  <1, 1, -3>*100
  color rgb <1, 1, 1>
  shadowless
background { color blue 0.5 }
Date: 6 Oct 2003 10:34:29
Message: <Xns942AA85E6E329torolavkhotmailcom@204.213.191.226>
Tor Olav Kristensen <tor_olav_kCURLYAhotmail.com> wrote in
news:Xns### [at] 204213191226:
>> surface.
> uv-mapped surface.
And here is some code that shows how to draw implicit curves
on such a surface.
(It should be possible to make a function that corrects the
change in line width along the curve.)
Tor Olav
#version 3.5;
#include "functions.inc"
#declare LW = 0.02; // Line Width
#declare SelFn =
  function(A) {
#declare DrawFn =
  function(u, v) { f_sphere(u, v, 0, 0.3 + 0.1*cos(6*f_th(u, 0, v))) }
//#declare DrawFn = function(u, v) { sqrt(u*u + v*v) - 0.4 }
bicubic_patch {
  type 0
  flatness 0.01
  u_steps 4
  v_steps 4
  uv_mapping
      function { SelFn(DrawFn(u - 0.5, v - 0.5)) }
      color_map {
light_source {
  <1, 1, -3>*100
  color rgb <1, 1, 1>
  shadowless
