POV-Ray : Newsgroups : povray.general : Weird rendering situation Server Time
27 Dec 2025 16:48:18 EST (-0500)
  Weird rendering situation (Message 1 to 10 of 10)
Subject: Weird rendering situation
Date: 23 Aug 2003 07:43:12
Message: <Xns93E04E3F73500POVMIKA@204.213.191.226>
Hi folks,
I've been dabling with Rune's particle system (very neat)
and don't really think it is his code that is the problem,
maybe just a circumstance of events (objects).
I have an animation sequence with options +kff300 +kf7,
the parsing is runs through, but the rendering sometimes
"hangs" forever in a frame, consumes all CPU and memory
consumption is not affected.
At first I though something was wrong with my code or
his code but then realised that the parsing would always
finish without a glitch.
I'm not quite sure how the at least try to debug this.
Any double_illuminate ideas?
Thanks
(MIKA) Marc Champagne
marcch.AT.videotron.DOT.ca
Montreal, CANADA
Subject: Re: Weird rendering situation
Date: 23 Aug 2003 08:10:49
Message: <Xns93E052EDE33F6POVMIKA@204.213.191.226>
Marc Champagne <nos### [at] pleasecom> wrote in
news:Xns### [at] 204213191226:
> Hi folks,
> Thanks
I am not using AA
Montreal, CANADA
Date: 23 Aug 2003 08:11:41
Message: <3f4759fd@news.povray.org>
For the record, I've had a similar problem in stills and wasn't able to
debug it. It's a bug, because stoping and restarting (with +C) the render
did allow the render to continue normally. It's repeatable (tested on
another machine), but I've not been able to make a scene simple enough to
test it and submit it as a real bug :(
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 23 Aug 2003 08:25:32
Message: <Xns93E0556CD361CPOVMIKA@204.213.191.226>
"Gilles Tran" <git### [at] wanadoofr> wrote in news:3f4759fd@news.povray.org:
> news:Xns### [at] 204213191226...
> render did allow the render to continue normally. It's repeatable
> (tested on another machine), but I've not been able to make a scene
> simple enough to test it and submit it as a real bug :(
At least I'm not alone :)
Montreal, CANADA
Date: 24 Aug 2003 13:29:32
Message: <Xns93E188E22779FPOVMIKA@204.213.191.226>
With a lot of tweaking, I managed to figure out what was causing the
"hanging", the 2 commented paramters are the culprits.
That is as far as I can go though.
#declare Stream =
      pigment  {  color rgb <0.93,0.62,0.64> * 1.2 }
      finish   {  diffuse     0.85
                  ambient     0
                  specular    0.9
                  roughness   0.03
                  phong       1.0
                  brilliance  7.3
                  phong_size  80
                  // metallic    .5
                  // reflection { 0.6, .95 metallic }
Montreal, CANADA
Date: 25 Aug 2003 17:26:34
Message: <3f4a7f0a@news.povray.org>
>                   // metallic    .5
Interestingly, the scene where I had the same problem also contained these
keywords, and stopped on the object that was textured that way.
G.
- Posters
Date: 25 Aug 2003 20:12:48
Message: <Xns93E2CD4315E21POVMIKA@204.213.191.226>
"Gilles Tran" <git### [at] wanadoofr> wrote in news:3f4a7f0a@news.povray.org:
>>                   // metallic    .5
> these keywords, and stopped on the object that was textured that way.
Col. Mustard in Living Room with candle stick.
Montreal, CANADA
Date: 29 Aug 2003 18:28:32
Message: <Xns93E6BB94410D1POVMIKA@204.213.191.226>
>>                   // metallic    .5
Gilles, do you know if this problem is being or will be looked into?
Marc Champagne
Montreal, CANADA
Date: 29 Aug 2003 19:33:35
Message: <Xns93E6C69BB6743POVMIKA@204.213.191.226>
>>                   // metallic    .5
Gilles, where these keywords attached to a blob by any chance?
Marc Champagne
Montreal, CANADA
Date: 29 Aug 2003 21:39:03
Message: <Xns93E6DBE202562POVMIKA@204.213.191.226>
>>                   // metallic    .5
I appear to have "fixed" my problem.
My original code was attaching the texture to each blob object, as is:
blob {
  #while ( many )
    	sphere{ x,x,x texture {...} }
By moving the texture out of each object and into the blob, POV does not
"Hang" any more.
blob {
  #while
    	generate many sphere{x,x }
  texture {...}
Marc Champagne
Montreal, CANADA
