POV-Ray : Newsgroups : povray.general : Problem: Bad code causes access violation exception Server Time
22 Mar 2026 15:26:08 EDT (-0400)
  Problem: Bad code causes access violation exception (Message 1 to 6 of 6)
Subject: Problem: Bad code causes access violation exception
Date: 24 Jan 2003 11:24:33
Message: <Xns930DB1A9241CEtorolavk@204.213.191.226>
This (bad) code;
#declare AA = array[1] { x }
#declare AA = #declare AA[0] = y;
#declare AA = #declare AA[0] = z;
plane { y, 0 }
- results in this error message:
"The POV-Ray core rendering code caused an access violation exception."
- when I run it in POV-Ray for Windows v3.5
POV-Ray is not shut down after this error
message (and is able to render other scenes
correctly).
Can anyone else confirm this behaviour ?
My PC runs Win98 SE and has a 166MHz MMX
Pentium processor with 96MB of RAM.
Tor Olav
Subject: Re: Problem: Bad code causes access violation exception
Date: 24 Jan 2003 11:33:45
Message: <kjq23vos77q95vc6jhaeulkh3bud730ig3@4ax.com>
On 24 Jan 2003 11:24:33 -0500, Tor Olav Kristensen <tor### [at] hotmailcom>
> plane { y, 0 }
I can confirm but it is what is called 'justice for wrong syntax' ;-)
ABX
Date: 24 Jan 2003 11:44:24
Message: <Xns930DB506E2009torolavk@204.213.191.226>
ABX <abx### [at] abxartpl> wrote in
news:kjq23vos77q95vc6jhaeulkh3bud730ig3@4ax.com:
>> plane { y, 0 }
> ABX
Thank you.
Tor Olav
Date: 25 Jan 2003 13:15:15
Message: <Xns930EC46FEF678torolavk@204.213.191.226>
Tor Olav Kristensen <tor### [at] hotmailcom> wrote in
news:Xns### [at] 204213191226:
> This (bad) code;
> plane { y, 0 }
> correctly).
I had hoped that this could be tested on
a MAC and a Linux machine too.
Further testing shows that this code:
#declare AA = #declare AA = y;
#declare AA = #declare AA = z;
sphere { 0*y, 0 }
- leads to POV-Ray giving this error
message in the Messages window:
"Parse Error: Attempt to free NULL pointer
(File: ..\..\source\parse.cpp Line: 8222)."
I wonder if this is the same bug, or if
this one is somehow triggered by the zero
radius sphere. When I change the radius to
1 I get the same "Access violation" error
as with the first script I listed.
Tor Olav
Date: 25 Jan 2003 13:58:52
Message: <3e32de6c@news.povray.org>
Confirmed on Debian Linux; kernel 2.4.18; Duron800MHz/256MB. POV crashes
with a segmentation fault. With a zero-radius sphere, gives the "attempt to
free a null pointer" error and segfaults.
Date: 25 Jan 2003 14:10:04
Message: <web.3e32dfdc6f48fe84b417814a0@news.povray.org>
Thank you Johannes.
Tor Olav
