POV-Ray : Newsgroups : povray.general : environment mapping Server Time
4 Mar 2026 05:11:57 EST (-0500)
  environment mapping (Message 1 to 10 of 21)
Subject: environment mapping
Date: 6 Sep 2002 19:26:30
Message: <Xns9282DFAC8B21raf256com@204.213.191.226>
Hellow,
can I add standart environment mapping to be usend in reflectio of object ?
ofcourse this is much more primitive then standart reflection, but
- it saves time
- can be used in some artistics effects
- allow to have POV scene acting same as in some other renderers
btw, about pigment as function - how about allow defining functions basing
not only on x,y,z but alsow on u,v (uv-mapping) and nx,ny,nz (normal
vector) ?
Subject: Re: environment mapping
Date: 7 Sep 2002 05:57:08
Message: <Xns928278E68625Craf256com@204.213.191.226>
"Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote in
news:Xns### [at] 204213191226
> Hellow,
> can I add standart environment mapping to be usend in reflection of
> object ?
from number of responses, I quess that environment mapping is NOT
implemented :P
So this is in fact a future request.
Date: 7 Sep 2002 06:37:57
Message: <3d79d705$1@news.povray.org>
"Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote in message
> implemented :P
Yes, I thought it was a 'future request'. I was planning on answering you a week on
Friday
Andy Cocker
Date: 7 Sep 2002 06:58:47
Message: <gv8z2CAOsde9EwrX@econym.demon.co.uk>
>> Hellow,
>> object ?
>implemented :P
Whatever it is that you want to achieve with this environment mapping
can almost certainly be achieved with the existing features.
One method would be to paint your environment picture onto a sphere
which surrounds your scene. Set no_image on the environment sphere and
no_reflection on the objects in your scene that you don't want to be
reflected.
Another method would be to use a layered texture on your object. One of
the layers would a mirror image image_map of the environment.
But to produce the best result, and using the simplest code, I'd suggest
actually putting your environment into the scene and allowing it to be
truly reflected. Environment mapping is an ugly kluge for systems that
can't manage real reflections.
By the way, the spell checker on your news client seems to be severely
broken.
Mike Williams
Gentleman of Leisure
Date: 7 Sep 2002 07:15:27
Message: <Xns9282862D56F53raf256com@204.213.191.226>
Mike Williams <mik### [at] econymdemoncouk> wrote in
news:gv8### [at] econymdemoncouk
how would example code look ?
I know, but env_mapping can be _much_ faster even 300% or more faster in
scenes with strong reflections. And it can be used to generate un-realistic
but artistic images.
> broken.
well if it is a problem You can always fix it using Yours news-reader KF ;)
Date: 7 Sep 2002 08:03:47
Message: <3D79EB22.B5958C53@gmx.de>
That's nonsense, you should not try to compare apples and pears.  True
environment mapping is only possible in a scanline renderer and
programming something similar in a raytracer will not be significantly
faster than using the no_image/no_reflection trick with an image mapped
object Mike mentioned.
I don't think there is anything useful that's possible with enviroment
mapping that won't work with true raytraced reflections and tricks like
no_image/no_reflection.
> > broken.
You just should notice that refusing to take some care about correct
typing clearly shows disrespect towards the readers of the posting.
Date: 7 Sep 2002 08:05:38
Message: <3d79eb92@news.povray.org>
Xns### [at] 204213191226...
> Hellow,
-> Search the help for environment mapping
-> Read 6.4.2.8  Spherical projection
-> Create a scene and render it using spherical mapping (angle 360,180)
(see the scene spherical.pov in the demo scenes)
-> Use the resulting image as a map on your object :      image_map{sys
"envmap" map_type 1}
-> Should like nice enough in some situations
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 7 Sep 2002 08:53:37
Message: <Xns928296D2175E0raf256com@204.213.191.226>
"Gilles Tran" <git### [at] wanadoofr> wrote in news:3d79eb92@news.povray.org
> image_map{sys
are You shure that this will act as reflection for non-spherical shapes ?
Date: 7 Sep 2002 09:46:22
Message: <3d7a032e@news.povray.org>
> > image_map{sys
I tested it on the default blob of the insert menu (using a
Terragen-generated environment). Depends on whether you want it to be
accurate or just look good...Just try it and see if you like it (and if it's
worth it).
G.
- Posters
Date: 7 Sep 2002 15:56:32
Message: <3d7a59f0@news.povray.org>
  This basically projects the scene onto the surface of the object (towards
the origin). Environment mapping does more than this (if well done).
  In (well-implemented) scanline rendering environment mapping works in the
same way is if you put the environment map as sky_sphere and make your object
reflective. That is, the rendering engine takes the value from a place in the
map that corresponds to the true reflection (ie. taking into account the
normal vector of the surface at the current point as well as the direction
of the camera). It involves some similar math that a raytracer does (even
though no rays are traced, of course).
  To get environment mapping, make a sky_sphere with your map (which could
be generated by rendering a scene with a spherical camera or whatever) as
as spherical map and simply make your object reflective. If there are no
other objects in the scene, you'll get exactly the same environment mapping
as in scanline renderers (if there are other objects, they will be reflected
as well, unless they have no_reflection defined).
  Of course the advantage of doing this is debatable.
