POV-Ray : Newsgroups : povray.general : IOR + dispersion - help Server Time
23 Feb 2026 23:52:52 EST (-0500)
  IOR + dispersion - help (Message 1 to 9 of 9)
Subject: IOR + dispersion - help
Date: 21 Jul 2002 13:38:00
Message: <Xns9252C72634CC5raf256com@204.213.191.226>
I have problem with my scene. I posted here full source and link to images.
Problem is with glass texture. Everything is o.k., until I add dispersion.
I want to get nice rainbow (photons+dispersion). But adding dispersion
makes glass very dark, even at pigment color rgbf 1 (without dispersion it
is totaly clear ofcourse).
Is there some way to add filter to dispersion effect ? btw. how can I get
rid of that yellow sircle around lower-right part of glass ?
IMHO it would be good idea to allow setting diffrent dispersion that is
used to calculate glass color, and diffrent to calcualate photons.
How can I both have nice rainbow photons on gray bacground, and have very
clear glass (like color rgbf .99)
With    dispersion  http:\\www.raf256.com\t\a4_1.jpg
Without dispersion  http:\\www.raf256.com\t\a4_2.jpg
Most important - glass material :
---8<-------------------------------------------------------------
      pigment { color rgbf 1 /*<.93,.98,.999, .98>*/ }
      finish {
        specular .8 roughness 0.001
        //phong 0.4 phong_size 140
        reflection { .03 .11 }
        diffuse .60
        ambient 9
    interior {
      ior 1.70 fade_power 1 fade_distance 50
      dispersion 1.4 dispersion_samples QQ_Disp //  <== PROBLEM
DD_Disp is 6..60 - it makes no important change.
Full source (a4.pov) You can copy/paste it, it only needs file "a.inc" -
look at end of this post
  P-111 MGlass (scan) buton (class A)
  1:1 ratio
  started 20.07.2002, last ver 0.50 21.07.2002 for 3.5win
  /o  \
#declare QQ_Rad = 0; // 0,1,2   3,4,5 light sphere
#declare QQ_Phot = 1.00; // 0=off   n.=spacing lower is better  good 0.1
//final 0.04
#declare QQ_Disp = 0.10 * 60; // dispersion samples
#declare QO_BackGr = 1;
#declare OF_MGlass = 1;
#declare CfgBackgrTest=0;
#declare CfgAreaSize=4000;
#declare CfgCamRotate =<0,0,0>;
#declare CfgCamRotateP=<0,0,20>;
//plane { z,35 pigment { checker color rgb 0 color rgb 1 }  scale 2 }
#declare objGlass = union {
  #declare matGlass = material {
      finish {
        diffuse .60
        ambient 9
    interior {
  #declare matMetall = material {
      pigment { color rgb .9 }
      finish { specular 0.9 roughness 0.010 reflection { .1 .3 metallic }
        diffuse .85
  #declare matHandleWood = material {
      #declare _c1 = <1.00,0.70,0.55> * 0.70;
      #declare _c2 = <1.00,0.80,0.65> * 0.95;
      #if (1)
      pigment { wood rotate x*90 scale .08 turbulence .05 translate 12
        color_map{
          [0.00 color rgb _c1]
          [0.30 color rgb _c1]
          [0.70 color rgb _c2]
          [1.00 color rgb _c2]
      } #else pigment { color rgb 1 } #end
      normal { wood rotate x*90 scale .08 turbulence .05 translate 12 }
      finish {
        specular .6 roughness 0.03
        phong 0.6 phong_size 20
        brilliance 1.3 diffuse 0.85
  #declare _R = 5.2 ;        // glass radius
  #declare _RTh = 0.45;      // ring around glass R-Thickness
  #declare _RRo = _R+_RTh/2; // radius of Ring - outer
  #declare _RRi = _R-_RTh/2; // radius of Ring - inner
  #declare _RH = 0.7;  // ring (metal) height
  intersection { // main GLASS
    sphere { -z*10 12 }
    sphere { +z*10 12 }
    cylinder { -z*100, +z*100, _R }
    material { matGlass }
    photons{ reflection on  refraction on target }
  union{
    difference {
      cylinder { -z*_RH, +z*_RH,     _RRo }
      cylinder { -z*(_RH+.1), +z*(_RH+.1), _RRi }
    torus { _R _RTh/2 rotate x*90 translate +z*_RH }
    torus { _R _RTh/2 rotate x*90 translate -z*_RH }
    material { matMetall }
    photons{ reflection on  refraction off target }
  // Hand
  #declare objHand = union {
    //cone { 0, 1, -y*8, 1 }
    sor {
      9
      <1.00  ,-1>
      <1.00,0>
      <0.90,0.50>
      <1.00,1.50>
      <1.10,3.00>
      <1.10,4.50>
      <1.05,6.00>
      <1.00,8.00>
      <1.00,9.50>
      sturm
      scale <1,-1,1>
    sphere { -y*8 1 }
    scale 0.93*<1.25, 1.25, 0.9>
    translate -y*_R
    material { matHandleWood }
  object { objHand }
  rotate x*5
  rotate z*40
  scale 3.2
  translate z*100
  translate <-13,13,0>
// translate z*100
// translate <-10,10,0>
object { objGlass }
#include "a.inc"
some lines with comments may word-arp, so this file is alsow on
http:\\www.raf256.com\t\a4.pov
http:\\www.raf256.com\t\a4.txt (same file just different extension)
NEEDED INCLUDE FILE -  a.inc  containing radiosity / photons settings and
background plane is here :
http:\\www.raf256.com\t\a.inc
http:\\www.raf256.com\t\a.txt (same file just different extension)
Subject: Re: IOR + dispersion - help
Date: 21 Jul 2002 13:55:37
Message: <3d3af599@news.povray.org>
1.4 is quite high for dispersion, realistic values are in the range of  1.01
or so.  1.1 can give nice but unrealistic results.  The dispersion value is
basically the ratio of the ior for red to the ior for violet for a given
material.   I have an ior include file that has iors and dispersion values
for a lot of different materials and that is essentially how the values
look:
ior = (ior_red+ior_violet)/2
dispersion = ior_red/ior_violet
-tgq
Date: 21 Jul 2002 14:46:40
Message: <chrishuff-01B10A.13394821072002@netplex.aussie.org>
In article <3d3af599@news.povray.org>,
> look:
Also, consts.inc has dispersion values defined for quartz glass, water,
diamond, and sapphire.
Unrealistic values can give interesting effects though...in
newdiffract.pov I used 0.1.
Date: 21 Jul 2002 15:28:19
Message: <Xns9252D9D96A3C3raf256com@204.213.191.226>
"TinCanMan" <Tin### [at] hotmailcom> wrote in
news:3d3af599@news.povray.org
>  1.01 or so.  1.1 can give nice but unrealistic results.  The
> dispersion value is basically the ratio of the ior for red to the ior
> for violet for a given material.   I have an ior include file that has
> iors and dispersion values for a lot of different materials and that
> is essentially how the values look:
I partialy fixed problems - the filter in pigment was too big, and ambient
was almost ignored.
But still - why using even dispersion 1.00001 makes objct _much_ brighter -
so I have to change amient from 0.0 to about 1.0 to have simmilar results
as with no dispersion
Now I use following material, and it gives nice results
      pigment { color rgbf <.93,.98,.999, .98> }
      finish {
        phong 0.2 phong_size 20
        diffuse .60
        ambient 2
    interior {
      dispersion 1.2 dispersion_samples QQ_Disp
Date: 21 Jul 2002 15:30:28
Message: <Xns9252DA36C1600raf256com@204.213.191.226>
"Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote in
news:Xns### [at] 204213191226
> brighter - so I have to change amient from 0.0 to about 1.0 to have
much DARKER ofcourse :)
btw. will news.povray.org allow supersede messages ?
Date: 21 Jul 2002 15:42:59
Message: <3d3b0ec3$1@news.povray.org>
When using photons, you should add 'collect off' to the photon block of
your glass objects.
see 6.10.4 and 6.10.2
-tgq
Date: 21 Jul 2002 15:50:06
Message: <3d3b106e$1@news.povray.org>
Another little piece of advice (if you are using 3.5):
in your camera declaration use:
  up y
the image proportions don't get distorted if you change the aspect ratio of
the output file, it gets calculated automatically.
-tgq
Date: 21 Jul 2002 16:13:26
Message: <Xns9252E17F2D8AAraf256com@204.213.191.226>
news:3d3b0ec3$1@news.povray.org
> your glass objects.
collect off will make glass same, or darker, while I want to make it
brighter.
Subject: IOR bug ? - was: IOR + dispersion - help
Date: 22 Jul 2002 14:30:57
Message: <Xns9253D01FEA9ECraf256com@204.213.191.226>
after some tests with this magnifing glass, I think I found a bug in
dispersion + photons + filter objects.
My image looks different in mosaic preview then in single-pass render !
The final mosaic step (1x1) is identical to single-pass, BUT mosaic steps
(2x2, 4x4, etc) - look different. IMHO 2x2 looks correct, while 1x1 image
have bug.
The problem is 'clearness' (filter) of glass. It sometimes look like glass,
sometimes like plastic with very low filter like .2
2x2 mosaic, dispersion 1.3  - nice glass (OK)
1x1 mosaic, dispersion 1.3  - plastic glass (wrong)
2x2 mosaic, no ispersion    - nice glass (OK)
1x1 mosaic, no dispersion   - nice glass (OK)
look at image posted to .b.i (under Magnyfing glass subject) it's upper
half is with 1x1 mosaic (plastic-glass) and lower part is 2x2 mosaic (nice
glass).
same image: http:\\www.raf256.com\b\a4_pre.jpg
