POV-Ray : Newsgroups : povray.general : bug - boxed, dispertion Server Time
29 Dec 2025 09:22:43 EST (-0500)
  bug - boxed, dispertion (Message 1 to 4 of 4)
Subject: bug - boxed, dispertion
Date: 11 Jul 2002 19:38:10
Message: <Xns92491011E295Araf256com@204.213.191.226>
I found 2 possible bugs in pov 3.5 win32
1) boxed pattern - it don't work (in every point it returns 0.0), and when
I replaced boxed with function - I just copy/paste formule from manual - it
worked correctly
2) dispertion. I make a sphere, rander it about 20 times (with or without
radiosiy, with on/off coustics, ior etc). I added dispertion - but it did't
work. Neither dispertion 1 or 1.5 or 100, disp_samples 10 or 100 etc.
After I close Pov, and start it again (to reload resolution init file) - it
worked o.k.
Subject: Re: bug - boxed, dispertion
Date: 11 Jul 2002 19:53:19
Message: <Xns924912A354155raf256com@204.213.191.226>
"Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote in
news:Xns### [at] 204213191226:
3)
  area_light x,y,0,0
  circular orient
results in memory allocation error, instead of reporting parse error
Date: 12 Jul 2002 02:33:40
Message: <n6tsiu83u8ppufvp53nhpvp8n640gsaiu2@4ax.com>
On 11 Jul 2002 19:38:10 -0400, "Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote:
> worked correctly
Can't confirm
Try this example:
// SCENE
  plane{
    -z , 0
    pigment{
      boxed
      color_map{
        [0 rgb 0]
        [1 rgb 1]
    finish{
      ambient 1
      diffuse 0
    translate z*3
// SCENE
> worked o.k.
Can't confirm. /scenes/lights/dispersion_photons.pov works fine for me. Please
post exact scene and check first if you can repeat this effect.
ABX
Date: 12 Jul 2002 02:38:54
Message: <e2usiu8eqt4p9cu641f5lqrt73hehs8tul@4ax.com>
On 11 Jul 2002 19:53:19 -0400, "Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote:
> area_light x,y,0,0
> circular orient
Haven't you noticed 'Parse Error' string at begining or memory allocation
error message ?
I remember last time when I reported similiar thing I have recived "justice
for unfair input ;-)" from Thorsten :-)
ABX
