POV-Ray : Newsgroups : povray.general : problems rendering a reflective parabolic surface Server Time
4 Oct 2024 10:22:43 EDT (-0400)
  problems rendering a reflective parabolic surface (Message 1 to 5 of 5)
Subject: problems rendering a reflective parabolic surface
Date: 23 Feb 2004 18:36:12
Message: <Pine.LNX.4.44.0402232341590.5293-100000@lexx.infeline.org>
To do an experiment, I want to render a reflective parabolic surface (a
newtonian reflective lens, for the astronomy buffs). My problem is that
the surface stops being reflective if I make it too "flat". I have
renedered a sample here, where the object in the centre is supposed to be
a parabolic mirror pointing at the camera. You can view the image and the
source at:
  http://ketil.froyn.name/lens.tga
  http://ketil.froyn.name/lens.pov
The odd thing (to me, anyway) is that if I change the y-parameter from
f_paraboloid(x/2.1,y/0.5,z/2.1,1)
to
f_paraboloid(x/2.1,y/0.7,z/2.1,1)
then the lens looks fine.
Any hints on how to avoid the brown bands are appreciated, I've done some
experimenting with different parameters (as I'm sure you can see from the
messy .pov file) but haven't understood why they are there yet.
If I can get this solved, I'll be interested in finding out how I can
calculate exactly the depth of a parabolic surface. As an example, if I
would like to render a parabolic surface that is 200mm wide and 0.5mm deep
(let's say my scale is in millimeters), what would my f_paraboloid look
like?
Thanks.
Ketil Froyn
ket### [at] froynname
Subject: Re: problems rendering a reflective parabolic surface
Date: 23 Feb 2004 22:41:30
Message: <403ac7ea$1@news.povray.org>
"Ketil Froyn" <ket### [at] froynname> wrote in message
news:Pin### [at] lexxinfelineorg...
> source at:
>   http://ketil.froyn.name/lens.pov   (I had to prefix with "www" for
these)
It's the max_gradient being a little too low. Suggested number was above 2
when I rendered the scene and you had it at only 1.5. It turned out okay
then.
> like?
Egads... I have no idea, sorry.
Bob H.
http://www.3digitaleyes.com
Date: 23 Feb 2004 23:03:18
Message: <cjameshuff-9BD4F8.23040323022004@news.povray.org>
In article <Pin### [at] lexxinfelineorg>,
> source at:
Probably a precision issue. Try using smaller values for accuracy and/or
increasing max_gradient. Also, you might want to look at using a
polynomial shape for the parabola rather than an isosurface...it will
likely give more accurate results, possibly faster as well. Look in the
shapes_old.inc include file, specifically for Paraboloid_X and its
relatives.
BTW, you have an interesting name...I guess I'm not the only one who
thinks so, seeing that it's the first item on your web site. I guess you
don't have much trouble getting mixed up with other people...I sat next
to another Chris in Spanish class, and the teacher loved to turn in our
general direction and just say "Chris! You're next!".
http://tag.povray.org/
Date: 8 Mar 2004 09:36:25
Message: <o6vo40p32ceip2ar96paj94m5evpr71mv9@4ax.com>
On Mon, 23 Feb 2004 23:04:03 -0500, Christopher James Huff
You should have seen our class in high-school... there were 7 guys
named Nikolai, two of them having the same family name and on top of
that their surnames had the same initials. Not to mention that the
stem of the surname (i.e. his father's first name) of one of them was
actually a nickname/diminutive for a very common Bulgarian name which
happened to be the name of the other guy's father :)
Something like "John Richard Doe" sitting next "John Richie Doe" :)
One of our English teachers found out a solution for it - he just
named them Nick 1st to 7th and the Nick-names (sorry, couldn't resist
:) ) just stuck.
Peter Popov ICQ : 15002700
Subject: [OT] Re: problems rendering a reflective parabolic surface
Date: 8 Mar 2004 15:57:24
Message: <404cde33@news.povray.org>
In my school class there were two guys with the *same* name. They both have
a compound name, the same (it's a common compound name, however). In Spain
we have two surnames, one comes from our father, the other from our mother.
They both have the same surnames (the first one is not that common). They
used to have some arguments about who was 2nd and who was 3rd in the class
list (alphabetically). They reached a consensus: one of them would be 2nd
for a year, the other one would be 2nd next year... Both wore glasses
too... (and they are not relatives).
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
