![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hash: SHA1
I spent a few hours trying to convert a pile of PNGs into something
that would play on my MPEG player, and I wasn't able to make any of
the tools work. convert was able to make an MPEG video stream, but I
couldn't get from there to anything that would play in winamp or
Windows Media Player.
Is there a document out there that says "run your povray command with
the following options, take those images and run the following
commands, and tada, you've got an MPEG file which will play anywhere"?
Jack.
Jack Twilley
jmt at twilley dot org
http colon slash slash www dot twilley dot org slash tilde jmt slash
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (FreeBSD)
iD4DBQFAYx/1GPFSfAB/ezgRAjKhAKD+sLFTrJ/MuNWy1Mby13bRe7rFlgCYz9sL
YnvU9bmxoBvWx4Til5jOsw==
=FD2/
-----END PGP SIGNATURE-----
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <86w### [at] duchess twilley org>, jmt+use### [at] twilley org
says...
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
Hmm. http://ftp.imp.org/tech/vfpng.zip
This file once installed properly with TMPGEnc works nicely. Oops! That
link is dead, try:
http://news.povray.org/povray.binaries.utilities/thread/%3C3a82f26c@news.
povray.org%3E/
Maybe someone should drop a copy of this to the TMPGEnc people themselves
to host, since they are a lot less likely to vanish off the face of the
earth or at the very least are certainly a more likely place to look for
the file. :(
void main () {
call functional_code()
else
call crash_windows();
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hash: SHA1
>>>>> "Patrick" == Patrick Elliott <sha### [at] hotmail com> writes:
Jack> Is there a document out there that says "run your povray command
Jack> with the following options, take those images and run the
Jack> following commands, and tada, you've got an MPEG file which will
Jack> play anywhere"?
[... excellent TMPGEnc plugin info elided ...]
Patrick> Maybe someone should drop a copy of this to the TMPGEnc
Patrick> people themselves to host, since they are a lot less likely
Patrick> to vanish off the face of the earth or at the very least are
Patrick> certainly a more likely place to look for the file. :(
Mmm. I was hoping for a more OS-agnostic method, but if Windows is
what I have to use right now, I'll survive.
Jack.
(porting makempeg.tcsh to sh in hopes it'll work)
Jack Twilley
iD8DBQFAY2tPGPFSfAB/ezgRApWHAJ0edW3ZK0jWcc9g+L/JH4LwZxFhdwCeOJrt
+kWIO7MzbWYT7MMrm67JvJo=
=BH6s
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hash: SHA1
>>>>> "Jack" == Jack Twilley <jmt+use### [at] twilley org> writes:
Jack> Mmm. I was hoping for a more OS-agnostic method, but if Windows
Jack> is what I have to use right now, I'll survive.
Jack> Jack.
Jack> (porting makempeg.tcsh to sh in hopes it'll work)
And it does!
http://www.twilley.org/~jmt/tmp/makempeg.sh.gz
If there's a general repository for stuff like this, please feel free
to include it. The original had no explicit license, so neither does
mine.
Jack.
Jack Twilley
iD8DBQFAY5dvGPFSfAB/ezgRAgVbAKCpl7+0KvHXwoPxDukh8btSTOTkYgCfREp4
/lhAnutMnp9+lmEOhiKxbs4=
=vrdU
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Yet another frequently asked question -- making MPEGs
Date: 28 Mar 2004 11:30:24
Message: <4066fda0@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I'm using mencoder from the mplayer package successfully for that.
See: www.mplayerhq.hu
It can even play the PNG files as video without prior conversion using
mplayer mf://"frame*.png"
Wolfgang
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
