POV-Ray : Newsgroups : povray.general : PNG to MPEG Server Time
20 Apr 2026 14:39:52 EDT (-0400)
  PNG to MPEG (Message 1 to 10 of 12)
Subject: PNG to MPEG
Date: 28 Jul 2003 18:15:12
Message: <MPG.198f4d5815abd00b989848@news.povray.org>
Seems the people at TMPGEnc are suffering from Digital Rube Goldberg
Syndrome. You may not have heard of it, but I am sure you have seen it.
The symptoms are having someone write a program to do something
incredibly useful, then they stare at you, like you have grown an extra
head, when you ask them why they don't add support for something that
could let you do something in one step with their program, but currently
requires 10 steps and 5 other programs to accomplish. lol (Ok. Maybe 2-3
programs and steps in this case, but that isn't much better imho.)
In any case, I recently ran all the animation samples from POV-Ray, with
the output set to PNG. You know, 'in order to maintain the correct
colors, the image quality and still save space.' Totally novel concept I
know. ;) I ended up having to batch convert all the damn things into BMP
and just about gave Windows a heart attack on one set of 600 images when
it started to run out of disk space. So... the questions I have are:
1. Is there anything out there that will do what TMPGEnc won't and
compress PNG into an MPEG stream? If not, then >
2. Are AVI compressed at all and if so, how much image quality loss do
you have to worry about when using TMPGEnc to convert them to an MPEG
stream. If they are compressed and the result of the second compression
to MPEG isn't a disaster >
3. Is there actually anything out there that will create an AVI from PNG
files.
void main () {
    call functional_code()
  else
    call crash_windows();
Subject: Re: PNG to MPEG
Date: 28 Jul 2003 18:32:24
Message: <3f25a478$1@news.povray.org>
Maybe transcode (not sure if there is a Windows version, though)
This thing is a must have (video swiss knife). Far from perfect, but quite
usefull.
Not sure it does PNG to MPEG, but it sure does a lot of format conversion.
http://www.theorie.physik.uni-goettingen.de/~ostreich/transcode
regards,
Pascal.
Date: 28 Jul 2003 18:39:17
Message: <3f25a5fe.128368143@news.povray.org>
On Mon, 28 Jul 2003 15:10:50 -0700, Patrick Elliott <sha### [at] hotmailcom>
My copy of  TMPGEnc 2.5 converts Pov created png's to mpg
Regards
Date: 28 Jul 2003 18:49:22
Message: <3f25a872@news.povray.org>
PNG
> files.
Animation shop (comes with Paint shop pro) does PNG (and "every" other
largely used format) to avi (divx/xvid etc)
It's not good (fast) at handling animations with a lot of frames though.
( I think my 450mhz kneeled at 500-1000 frames IIRC)
You can get a trial version at www.jasc.com
-Peter
Date: 28 Jul 2003 23:20:42
Message: <Xns93C6D9AC1EF17ZenPsychoyahoocom@204.213.191.226>
the answers to all your hopes and dreams are contained within this link:
http://news.povray.org/povray.binaries.utilities/15796/
Date: 28 Jul 2003 23:28:25
Message: <t7qbiv4eqab60uf61cju1aue16p5vpmnk6@4ax.com>
Also sprach mca### [at] aolcom (S McAvoy) -- Mon, 28 Jul 2003 22:39:16 GMT:
Yes, mine does too.  You need to fetch the addin.
See p.b.u "PNG reader for TMPGEnc" Peter Harris 2001-02-08
dik
Date: 28 Jul 2003 23:32:07
Message: <MPG.198f97967fa24161989849@news.povray.org>
In article <3f25a5fe.128368143@news.povray.org>, mca### [at] aolcom (S
McAvoy) says...
Odd.. That is the one I just downloaded. It doesn't list PNG as a valid
file type in the input box. It also generates and error when it tries to
read one you enter manually. Unless you are using the Pro version or
something and it has extra support of formats or there is some sort of
plugin for it....
In any case, it seems the person that answered me on the forum for
TMPGEnc misinterpreted what I said initially. For some reason any
'serious' attempt by me to explain things and make suggestions causes
this to happen. lol Turns out you can use something called AviSynth to do
this, or AviSynth combined with one called VirtualDubMod.
VirtualDubMod appears to let you edit and tweak the 'stream' before
encoding. This includes changing the frame rate, etc. Something that
kind of bugs me about TMPGEnc anyway, since I would love to be able to
tell it 'this video should be more or less 2 minutes long' and have it
set the correct frame rate to make it that long.
AviSynth though appears to work like a codec, only it runs a script that
will process each frame as needed, I.e. converting from PNG to something
TMPGEnc or players understand for each frame. The nice thing about this
is you could probably write an include that could automatically generate
the script needed to either play back the existing images through a media
player, without encoding them to MPEG, or to feed them to TMPGEnc in
order to perform the encoding.
The links are:
http://www.avisynth.org/
http://virtualdubmod.sourceforge.net/?page=faq
I still think my Rube Goldberg Syndrome is all too real when dealing with
POV-Ray though. ;) lol
void main () {
  else
Date: 29 Jul 2003 00:40:30
Message: <Xns93C76B2D4362tomatimporg@204.213.191.226>
Breton Slivka <blah> wrote in news:Xns93C6D9AC1EF17ZenPsychoyahoocom@
204.213.191.226:
Do you think Mr. Harris is aware of how much we love his gift?
Tom
_________________________________
The Internet Movie Project
http://www.imp.org/
Date: 29 Jul 2003 01:40:01
Message: <web.3f2607a127dda6cea472d3920@news.povray.org>
Try RadTools (Bink and Smacker)...  It can do bunch conversion (audio, video
at different compression rate) and has AVI and MPEG output (as well as all
pic format)...  I downloaded it one year ago and it was totally free at
this time... A great tool for doing animation and game...  Anyway, check
their website at http://www.radgametools.com/bnkadvan.htm
Tommy
The 1st African citizen POV member !
http://www.webkenya.com/
Promote Web Development in Africa
WWW = Western or World Wide Web ??
Date: 29 Jul 2003 16:40:22
Message: <MPG.1990889f14d1108398984a@news.povray.org>
In article <t7qbiv4eqab60uf61cju1aue16p5vpmnk6@4ax.com>,
dik### [at] seeorganizationfield says...
Thanks, maybe a search on that will turn it up. lol The several attempts
I made failed to turn anything useful up.
void main () {
  else
